Introdução
Cracked the screen or the front cover of your Sparq? Have no fear - we'll teach you how to take apart the whole phone to replace the cracked cover.
This style of slide phone can be a little complex to disassemble but you can do it. To prepare, make sure you have a magnetic mat to hold all of the small 2mm screws and plenty of space to organize your parts.
O que você precisa
If you're looking at your phone from the front, feel the upper left hand rounded corner. You'll notice a thin opening between the front of the phone and the back cover.
Flip the phone over (as in the picture) and use a spudger or your finger to gently separate the back cover from the phone.
There are eight 2mm screws that must be removed from the back of the device using a Phillips #000 screwdriver. As you remove them it is wise to organize them into a small container or place them on a magnetic project mat for safe keeping.
Once the back case has been removed, gently lift the motherboard away from the phone keypad - do not yank. There is an electronic ribbon connecting the board to the other side of the phone.
Once you've identified the ribbon, gently pull the ribbon at the end connected to the motherboard until it comes off. It's sort of like an electronic lego - it will snap off of the board without much applied pressure.
You will see an orange electronic ribbon cable running from the green board at the bottom of the phone, over the back of the screen and finally attached to a metal cover that hides the ear speaker.
To remove the metal cover from the speaker, first take a close look at how it is connected to the phone. There are two metal prongs that hold the cover in place.
Use the thin end of a tool, like a spudger, to gently depress the prongs and simultaneously lift the cover off of the speaker.
The full screen/motherboard assembly simply comes out of the front case. If you have some difficulty removing it, you may use a thin tool (like a spudger) to help you lift it.
1Comentário do guia
Is there a screen replacement step by step for this phone? please and thank you
