Ir para o conteúdo principal
T-Mobile Huawei Prism U8651T Digitizer Replacement
O que você precisa
  1. T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Back Cover Panel: passo 1, imagem 1 %32 T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Back Cover Panel: passo 1, imagem 2 %32 T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Back Cover Panel: passo 1, imagem 3 %32
    • Place the phone face down.
    • Slide the back cover panel away from you, until you hear a click.
    • Lift the back cover panel off.
  2. T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Battery: passo 2, imagem 1 %32 T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Battery: passo 2, imagem 2 %32 T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Battery: passo 2, imagem 3 %32
    • Place the plastic opening tool in the gap between the camera and battery.
    • Pry the battery up.
    • Remove the battery.
  3. T-Mobile Huawei Prism U8651T Digitizer Replacement, Torx Screws: passo 3, imagem 1 %32 T-Mobile Huawei Prism U8651T Digitizer Replacement, Torx Screws: passo 3, imagem 2 %32 T-Mobile Huawei Prism U8651T Digitizer Replacement, Torx Screws: passo 3, imagem 3 %32
    Ferramenta utilizada nesse passo:
    T4 Torx Screwdriver
    $5.99
    Comprar
    • Locate the six 3mm torx screws holding the plastic mid frame in place.
    • Remove the six torx screws with the T4 torx screwdriver.
  4. T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Plastic Mid Frame: passo 4, imagem 1 %32 T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Plastic Mid Frame: passo 4, imagem 2 %32 T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Plastic Mid Frame: passo 4, imagem 3 %32
    • Place the plastic opening tool in the charging port.
    • Pry up to loosen the bottom edge of the plastic mid frame.
    • Work the plastic opening tool along the seam, until the the plastic mid frame is detached.
    • Remove the plastic mid frame.
  5. T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Power and Volume Buttons: passo 5, imagem 1 %32 T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Power and Volume Buttons: passo 5, imagem 2 %32
    • Locate the power button.
    • Locate the volume botton.
    • Slide the two buttons up and out of the phone.
    • The removed buttons are incredibly easy to lose, so be sure to keep an eye on them.
  6. T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Power Button Sensor Strip: passo 6, imagem 1 %32 T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Power Button Sensor Strip: passo 6, imagem 2 %32 T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Power Button Sensor Strip: passo 6, imagem 3 %32
    • Locate the power button sensor strip.
    • Place the plastic opening tool under the sensor strip.
    • Pry the sensor strip up.
  7. T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Volume Button Sensor Strip: passo 7, imagem 1 %32 T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Volume Button Sensor Strip: passo 7, imagem 2 %32 T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Volume Button Sensor Strip: passo 7, imagem 3 %32
    • Locate the volume button sensor strip.
  8. T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Outer Screen Connector: passo 8, imagem 1 %32 T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Outer Screen Connector: passo 8, imagem 2 %32 T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Outer Screen Connector: passo 8, imagem 3 %32
    • Locate the outer screen connector.
    • Place the plastic opening tool under the screen connector.
    • Pry the screen connector up.
  9. T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Inner Screen Connector: passo 9, imagem 1 %32 T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Inner Screen Connector: passo 9, imagem 2 %32 T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Inner Screen Connector: passo 9, imagem 3 %32
    • Locate the inner screen connector.
  10. T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Motherboard: passo 10, imagem 1 %32 T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Motherboard: passo 10, imagem 2 %32 T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Motherboard: passo 10, imagem 3 %32
    • Place the plastic opening tool in the charger port.
    • Pry the motherboard up.
    • Remove the motherboard.
  11. T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Screen: passo 11, imagem 1 %32 T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Screen: passo 11, imagem 2 %32 T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Screen: passo 11, imagem 3 %32
    • Pick up the front half of your phone with your left hand.
    • Slowly rotate the phone so the screen falls into your right hand.
    • Be extremely careful not to drop the screen.
  12. T-Mobile Huawei Prism U8651T Digitizer Replacement, Digitizer: passo 12, imagem 1 %32
    • Be sure to use the new digitizer when reassembling your phone.
Conclusão
5 outras pessoas executaram este guia.
Dillon
Membro desde: 10/23/14
578 Reputação
Autoria de 5 guias
Equipe
Michigan Tech, Team 1-7, Lauer Fall 2014 Membro de Michigan Tech, Team 1-7, Lauer Fall 2014
MTU-LAUER-F14S1G7
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Duração total: 606
