Ir para o conteúdo principal
Syntus ST150 Ultrasonic Plate Replacement
O que você precisa
  1. Syntus ST150 Ultrasonic Plate Replacement, Ultrasonic Plate: passo 1, imagem 1 %32
    • First, make sure the water tank inside the diffuser is completely dry to avoid any water from contacting the internal components.
    • Make sure the diffuser is disconnected from the power source to avoid electrical hazards.
  2. Syntus ST150 Ultrasonic Plate Replacement: passo 2, imagem 1 %32 Syntus ST150 Ultrasonic Plate Replacement: passo 2, imagem 2 %32
    • With a Phillips #1 screwdriver, remove the three 10 mm screws on the bottom of the diffuser.
  3. Syntus ST150 Ultrasonic Plate Replacement: passo 3, imagem 1 %32 Syntus ST150 Ultrasonic Plate Replacement: passo 3, imagem 2 %32 Syntus ST150 Ultrasonic Plate Replacement: passo 3, imagem 3 %32
    • Lift the water tank while holding the base of the diffuser.
    • Disconnect the three cables form the board.
    • Make sure when reassembling the diffuser to plug in each cable to its assigned port.
  4. Syntus ST150 Ultrasonic Plate Replacement: passo 4, imagem 1 %32 Syntus ST150 Ultrasonic Plate Replacement: passo 4, imagem 2 %32 Syntus ST150 Ultrasonic Plate Replacement: passo 4, imagem 3 %32
    • To separate the board from the water tank, unscrew the three Phillips #1 10 mm screws securing the board.
  5. Syntus ST150 Ultrasonic Plate Replacement: passo 5, imagem 1 %32 Syntus ST150 Ultrasonic Plate Replacement: passo 5, imagem 2 %32 Syntus ST150 Ultrasonic Plate Replacement: passo 5, imagem 3 %32
    • With a Phillips #0 screwdriver, remove the three 7 mm screws from the ultrasonic sensor cover.
    • Remove the cover to expose the ultrasonic sensor.
  6. Syntus ST150 Ultrasonic Plate Replacement: passo 6, imagem 1 %32 Syntus ST150 Ultrasonic Plate Replacement: passo 6, imagem 2 %32 Syntus ST150 Ultrasonic Plate Replacement: passo 6, imagem 3 %32
    • Detach the ultrasonic sensor from the water tank.
    • Detach the ultrasonic sensor connector from the board.
  7. Syntus ST150 Ultrasonic Plate Replacement: passo 7, imagem 1 %32
    • Remove the rubber cover from the ultrasonic plate.
  8. Syntus ST150 Ultrasonic Plate Replacement: passo 8, imagem 1 %32
    • Now you can replace the ultrasonic plate of your diffuser.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 26
Duração total: 343
