Ir para o conteúdo principal
Syma S107 Gyro Replacement
O que você precisa
  1. Syma S107 Gyro Replacement, Counterweight Bar: passo 1, imagem 1 %32 Syma S107 Gyro Replacement, Counterweight Bar: passo 1, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Using tweezers, gently remove the two stabilizing links by pulling straight away from the point of connection.
    Pergunte ao FixBot
    Comentar
  2. Syma S107 Gyro Replacement: passo 2, imagem 1 %32 Syma S107 Gyro Replacement: passo 2, imagem 2 %32
    • Remove the counterweight bar by removing the screw.
    • One 10.1mm Phillips #0.
    Pergunte ao FixBot
    Comentar
  3. Syma S107 Gyro Replacement, Gyro Carriage: passo 3, imagem 1 %32 Syma S107 Gyro Replacement, Gyro Carriage: passo 3, imagem 2 %32
    • Remove the gyro carriage by removing the following screws:
    • Two 5.6mm Phillips #0.
    • When reinstalling these screws make sure to line up one screw with the keyway on the main rotor shaft.
    Pergunte ao FixBot
    Comentar
  4. Syma S107 Gyro Replacement: passo 4, imagem 1 %32 Syma S107 Gyro Replacement: passo 4, imagem 2 %32
    • Gently remove the broken gyro carriage by pulling up.
    • Remove blade assembly by simply sliding it up and off the shaft.
    Pergunte ao FixBot
    Comentar
  5. Syma S107 Gyro Replacement, Blade Carriage: passo 5, imagem 1 %32 Syma S107 Gyro Replacement, Blade Carriage: passo 5, imagem 2 %32 Syma S107 Gyro Replacement, Blade Carriage: passo 5, imagem 3 %32
    • Again using tweezers gently remove the stabilizing links from the blade carriage by pulling straight away from the point of connection.
    Pergunte ao FixBot
    Comentar
  6. Syma S107 Gyro Replacement: passo 6, imagem 1 %32 Syma S107 Gyro Replacement: passo 6, imagem 2 %32
    • Remove the blades from the blade carriage by removing the following screws:
    • Two 4.7mm Phillips #0.
    Pergunte ao FixBot
    Comentar
  7. Syma S107 Gyro Replacement: passo 7, imagem 1 %32 Syma S107 Gyro Replacement: passo 7, imagem 2 %32
    • Remove the following screws:
    • Two 4.5mm Phillips #0.
    • Make sure to remove any broken plastic pins before reassembling the components.
    • You will have to slide the two halves of the blade carriage over the pins on the gyro carriage first when reassembling.
    Pergunte ao FixBot
    Comentar
Conclusão
7 outras pessoas executaram este guia.
Equipe
USF Tampa, Team 1-31, Donnelly Fall 2014 Membro de USF Tampa, Team 1-31, Donnelly Fall 2014
USFT-DONNELLY-F14S1G31
1 Membro
1 Guia de autoria
6Comentários do guia
Thank you for this guide! This has fixed the issue and made a 35 year old boy very happy!
Patrick haymer - Responder Compartilhar
Cheers thanks too this page I fixed problem  great ,  Martin
Martin Worboys - Responder Compartilhar
Same here, incidentally where can I get replacement batteries please? Also have a “Picolo” heli with a bad feedback IC , supposedly this part can also be replaced on some units as its a soldered vertical board on the main.
Andre - Responder Compartilhar
Thank you! Took forever to find an answer to my problem! Now very obvious thanks to you. My sanity is restored! HaHa!
CRC 04/04/2021
Chris - Responder Compartilhar
I’m halfway there and grateful for the directions. But I’m not having any luck removing the broken plastic pins from the blade carriage. I’ve tried using a needle but no luck. Did anyone else come up against this?
Adam Leavesley - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 81
Ao todo: 15,800
