Ir para o conteúdo principal
Sylvania SDVD9004 CD Drive Replacement
O que você precisa
  1. Sylvania SDVD9004 CD Drive Replacement, CD Drive: passo 1, imagem 1 %32 Sylvania SDVD9004 CD Drive Replacement, CD Drive: passo 1, imagem 2 %32 Sylvania SDVD9004 CD Drive Replacement, CD Drive: passo 1, imagem 3 %32
    • This guide uses incorrect tools. Use an ESD safe tool, such as a nylon spudger, to complete this step.
    • Wedge head lightly between drive and bottom of tab.
    • Repeat on both sides.
    • Gently pull out ribbon
  2. Sylvania SDVD9004 CD Drive Replacement: passo 2, imagem 1 %32
    • Drive Removal
    • Use Philip's screw driver to remove three 7 mm screws.
    • Rotate counter clockwise to loosen screws.
  3. Sylvania SDVD9004 CD Drive Replacement: passo 3, imagem 1 %32
    • Follow the red and black cables to the motherboard point of attachment.
    • Use a Flat head screwdriver.
    • Place head of driver into the grove of plug and port.
    • Wedge on all sides evenly to work out plug slowly.
    • Remove small and large plugs.
Conclusão
Sarah Henry
Membro desde: 10/31/16
417 Reputação
Autoria de 4 guias
Equipe
Baylor, Team 5-10, Williams Fall 2016 Membro de Baylor, Team 5-10, Williams Fall 2016
BU-WILLIAMS-F16S5G10
Membros da 2
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 9
Duração total: 579
