Ir para o conteúdo principal
Sweatshirt Hoodie Grommets Replacement
O que você precisa
  1. Sweatshirt Hoodie Grommets Replacement, Grommets: passo 1, imagem 1 %32 Sweatshirt Hoodie Grommets Replacement, Grommets: passo 1, imagem 2 %32
    • Grab the end of the hoodie of the string.
    • Pull the string towards yourself until it is out of the hoodie completely.
  2. Sweatshirt Hoodie Grommets Replacement: passo 2, imagem 1 %32 Sweatshirt Hoodie Grommets Replacement: passo 2, imagem 2 %32 Sweatshirt Hoodie Grommets Replacement: passo 2, imagem 3 %32
    • Use the seam ripper to tear the seam on the hoodie open.
    • Use scissors as necessary to cut excess thread.
    • Continue this process until the seam is open enough to put the grommet tool in. There should be a hole about 1"-2" long.
    • Seam ripper may cause injury if handled incorrectly.
  3. Sweatshirt Hoodie Grommets Replacement: passo 3, imagem 1 %32
    • Place the top section of the grommet over the desired hole.
  4. Sweatshirt Hoodie Grommets Replacement: passo 4, imagem 1 %32 Sweatshirt Hoodie Grommets Replacement: passo 4, imagem 2 %32
    • Flip the hole over and place the bottom piece of the grommet over the cylindrical section of the top piece.
    • Grab your grommet pliers and locate the side with the cone shaped nub. Make sure that the side with the nub is facing against the bottom piece of the grommet.
  5. Sweatshirt Hoodie Grommets Replacement: passo 5, imagem 1 %32 Sweatshirt Hoodie Grommets Replacement: passo 5, imagem 2 %32
    • Align the grommet pliers with both pieces of the grommet.
    • Squeeze the pliers with moderate pressure until the grommet becomes attached to the hoodie securely.
  6. Sweatshirt Hoodie Grommets Replacement: passo 6, imagem 1 %32
    • Thread a sewing needle with matching colored thread to mend the ripped area.
    • Follow How to Use a Needle Threader if you are unsure how to do this.
  7. Sweatshirt Hoodie Grommets Replacement: passo 7, imagem 1 %32 Sweatshirt Hoodie Grommets Replacement: passo 7, imagem 2 %32 Sweatshirt Hoodie Grommets Replacement: passo 7, imagem 3 %32
    • Re-attach the ripped area using your preferred sewing technique.
    • Use a scissor to cut off excess threads after finish sewing.
    • Follow How to Hand Sew A Small Hole in Clothing if you are unsure how to do this.
  8. Sweatshirt Hoodie Grommets Replacement: passo 8, imagem 1 %32
Linha de Chegada
Haiming Dong
Membro desde: 01/31/24
157 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team 4-5, Andersen Winter 2024 Membro de UC Davis, Team 4-5, Andersen Winter 2024
UCD-ANDERSEN-W24S4G5
3 Membros
1 Guia de autoria
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 17
Últimos 30 dias: 94
Ao todo: 659
