Ir para o conteúdo principal
Swatch Wristwatch Band Replacement
O que você precisa
  1. Swatch  Wristwatch Band Replacement, Problem of compatibility: passo 1, imagem 1 %32
    • Swatch band (blue) is very likely to fail (due to stress concentration and fatigue) and is different from a standard one (brown).
  2. Swatch  Wristwatch Band Replacement, Adapting the band to a swatch watch: passo 2, imagem 1 %32
    • Using Dremel carefully cut two slots to acomodate the band to the swatch body.
  3. Swatch  Wristwatch Band Replacement, Finished assembly: passo 3, imagem 1 %32
    • Here you go! Your band is adapted and assembled to your swatch.
    • Advise: Buy a good band with good thickness at the fulcrum, otherwise it may be weakened excessively by the cutting.
Conclusão
Good luck with battling the programmed obsolescence!
Michal Ruzek
Membro desde: 01/27/22
739 Reputação
Autoria de 7 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 17
Últimos 30 dias: 82
Ao todo: 628
