Ir para o conteúdo principal
Swann Doorphone Video Intercom Wire Replacement
O que você precisa
  1. Swann Doorphone Video Intercom Wire Replacement, Wire: passo 1, imagem 1 %32 Swann Doorphone Video Intercom Wire Replacement, Wire: passo 1, imagem 2 %32 Swann Doorphone Video Intercom Wire Replacement, Wire: passo 1, imagem 3 %32
    • Flip the monitor of the Swann Doorphone over so that the underside is facing up.
    • Grip the sides of the black rectangular frame where they extend outwards and pull down.
    • After pulling down, pull the frame towards you to remove it from the monitor.
  2. Swann Doorphone Video Intercom Wire Replacement: passo 2, imagem 1 %32 Swann Doorphone Video Intercom Wire Replacement: passo 2, imagem 2 %32 Swann Doorphone Video Intercom Wire Replacement: passo 2, imagem 3 %32
    • Using the JIS #0 screwdriver, unscrew the 2 mm screw in terminal 1 with the blue wire underneath.
    • Pull the blue wire out from beneath the metal plate.
    • Be careful when removing the screw from terminal 1, the metal plate behind the screw is not connected and may fall off.
  3. Swann Doorphone Video Intercom Wire Replacement: passo 3, imagem 1 %32 Swann Doorphone Video Intercom Wire Replacement: passo 3, imagem 2 %32 Swann Doorphone Video Intercom Wire Replacement: passo 3, imagem 3 %32
    • Flip the outdoor camera over so that the underside is facing up.
    • Remove the back cover by grabbing the sides of the camera and pulling towards your body.
  4. Swann Doorphone Video Intercom Wire Replacement: passo 4, imagem 1 %32 Swann Doorphone Video Intercom Wire Replacement: passo 4, imagem 2 %32 Swann Doorphone Video Intercom Wire Replacement: passo 4, imagem 3 %32
    • With the back cover of the outdoor camera off, press the first gray square button with blue wire down.
    • While pressing the gray square button, remove the blue wire from the first opening under the button.
    • Be sure to remove the same color wire for the outdoor camera as was used for the indoor video intercom.
    • In this guide, we are using the blue wire in terminal 1 for the audio. As a recommendation; * Use the blue wire in terminal 1 for the audio wire. * Use the brown wire in terminal 2 for the ground wire. * Use the green wire in terminal 3 for the video wire. * Use the black wire in terminal 4 for the power wire.
Conclusão
Emily Stenke
Membro desde: 02/14/18
555 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team S2-G4, Eyestone Spring 2018 Membro de USF Tampa, Team S2-G4, Eyestone Spring 2018
USFT-EYESTONE-S18S2G4
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 9
Duração total: 1,707
