Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
This guide will help you replace the wall mount of the Swann Doorphone Video Intercom. The wall mount is what is connected to your inside and outside walls.
O que você precisa
Flip the monitor of the Swann Doorphone over so that the underside is facing up.
Grip the sides of the rectangular frame where they extend outwards and slide it down.
After sliding down, pull the frame towards you to remove it from the monitor.
