Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Flip the monitor of the Swann Doorphone Video Intercom over so that the underside is facing up.
Remove the six 2 mm corner screws from the back plate of the monitor using the JIS #0 screwdriver.
Once the screws are removed, grip the black back plate of the monitor and remove from the monitor.
Using the precision tweezers, grab the sides of the white connector at the bottom of the green board.
Pull the white connector towards you to disconnect the board.
Grip the other end of the white connector cable towards the base of the black microphone.
Pull gently towards your body to remove the microphone.
