Ir para o conteúdo principal
Swann Doorphone Video Intercom Microphone Replacement
O que você precisa
  1. Swann Doorphone Video Intercom Microphone Replacement, Microphone: passo 1, imagem 1 %32 Swann Doorphone Video Intercom Microphone Replacement, Microphone: passo 1, imagem 2 %32 Swann Doorphone Video Intercom Microphone Replacement, Microphone: passo 1, imagem 3 %32
    • Flip the monitor of the Swann Doorphone Video Intercom over so that the underside is facing up.
    • Remove the six 2 mm corner screws from the back plate of the monitor using the JIS #0 screwdriver.
  2. Swann Doorphone Video Intercom Microphone Replacement: passo 2, imagem 1 %32 Swann Doorphone Video Intercom Microphone Replacement: passo 2, imagem 2 %32
    • Once the screws are removed, grip the black back plate of the monitor and remove from the monitor.
    • The back plate will still be connected to the monitor with a cord of wires that should not be removed.
  3. Swann Doorphone Video Intercom Microphone Replacement: passo 3, imagem 1 %32 Swann Doorphone Video Intercom Microphone Replacement: passo 3, imagem 2 %32 Swann Doorphone Video Intercom Microphone Replacement: passo 3, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using the precision tweezers, grab the sides of the white connector at the bottom of the green board.
    • Pull the white connector towards you to disconnect the board.
  4. Swann Doorphone Video Intercom Microphone Replacement: passo 4, imagem 1 %32 Swann Doorphone Video Intercom Microphone Replacement: passo 4, imagem 2 %32 Swann Doorphone Video Intercom Microphone Replacement: passo 4, imagem 3 %32
    • Grip the other end of the white connector cable towards the base of the black microphone.
    • Pull gently towards your body to remove the microphone.
Conclusão
Emily Stenke
Membro desde: 02/14/18
555 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team S2-G4, Eyestone Spring 2018 Membro de USF Tampa, Team S2-G4, Eyestone Spring 2018
USFT-EYESTONE-S18S2G4
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 15
Duração total: 392
