Ir para o conteúdo principal
Swann Doorphone Video Intercom Camera Replacement
O que você precisa
  1. Swann Doorphone Video Intercom Camera Replacement, Camera: passo 1, imagem 1 %32 Swann Doorphone Video Intercom Camera Replacement, Camera: passo 1, imagem 2 %32 Swann Doorphone Video Intercom Camera Replacement, Camera: passo 1, imagem 3 %32
    • Flip the outdoor camera over so that the underside is facing up.
    • Remove the back cover by grabbing the sides of the camera and pulling towards your body.
  2. Swann Doorphone Video Intercom Camera Replacement: passo 2, imagem 1 %32 Swann Doorphone Video Intercom Camera Replacement: passo 2, imagem 2 %32
    • With the back cover of the outdoor camera off, press the first gray button, with blue wire underneath, down as shown in the picture.
    • While pressing the gray square button, remove the blue wire from the first opening under the button.
    • Be sure to remove the same color wire for the outdoor camera as was used for the indoor video intercom.
  3. Swann Doorphone Video Intercom Camera Replacement: passo 3, imagem 1 %32 Swann Doorphone Video Intercom Camera Replacement: passo 3, imagem 2 %32 Swann Doorphone Video Intercom Camera Replacement: passo 3, imagem 3 %32
    • Remove the other wires using the same steps as the blue wire.
    • Using the JIS #0 screwdriver, remove the 2mm screws from the back plate.
    • Remove the back plate by pulling the plate away from the device.
  4. Swann Doorphone Video Intercom Camera Replacement: passo 4, imagem 1 %32 Swann Doorphone Video Intercom Camera Replacement: passo 4, imagem 2 %32
    • Using the JIS #0 screwdriver, remove the 1mm screws from behind the camera.
  5. Swann Doorphone Video Intercom Camera Replacement: passo 5, imagem 1 %32 Swann Doorphone Video Intercom Camera Replacement: passo 5, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using one of the tweezers from the Precision Tweezers Set, gently place them around the wire connector attached to the camera.
    • Pull slowly in the direction of the cables until the connector is no longer attached.
  6. Swann Doorphone Video Intercom Camera Replacement: passo 6, imagem 1 %32 Swann Doorphone Video Intercom Camera Replacement: passo 6, imagem 2 %32
    • Remove the camera from the device.
Conclusão
Emily Stenke
Membro desde: 02/14/18
555 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team S2-G4, Eyestone Spring 2018 Membro de USF Tampa, Team S2-G4, Eyestone Spring 2018
USFT-EYESTONE-S18S2G4
Membros da 4
Autoria de 5 guias
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 12
Duração total: 696
