Ir para o conteúdo principal
Swagtron T3 Cover Replacement
Pré-requisito somente
Este é um guia somente para pré-requisitos! Este guia faz parte de outro procedimento e não deve ser usado sozinho.
O que você precisa
    1. Swagtron T3 Cover Replacement, Cover: passo 1, imagem 1 %32 Swagtron T3 Cover Replacement, Cover: passo 1, imagem 2 %32
      • Make sure the hoverboard is completely powered off and unplugged from any outlets.
      • Flip the Swagtron so that the footpads are facing the ground.
      • Unscrew the sixteen 9.4 mm Phillips #1 machine screws on the side of the Swagtron that is now facing upwards.
      Pergunte ao FixBot
      Comentar
    2. Swagtron T3 Cover Replacement: passo 2, imagem 1 %32 Swagtron T3 Cover Replacement: passo 2, imagem 2 %32 Swagtron T3 Cover Replacement: passo 2, imagem 3 %32
      • Be careful with the small blue capacitors indicated by the orange box. There are many of these capacitors in the device.
      • Slowly lift the backside cover.
      • Both sides lift up the same way, but the motherboard is under one side and the battery is under the other.
      • Detach the four cables connected to the cover by pinching the connector clips and pulling the cables out:
      • Three cables on the motherboard side.
      • Two red cables with white connectors and one white cable with a white connector.
      • One yellow cable with a black connector on the battery side.
      • After detachment, you should be able to completely remove the backside cover.
      Pergunte ao FixBot
      Comentar
Conclusão
Equipe
Cal Poly, Team S13-G3, Forte Spring 2017 Membro de Cal Poly, Team S13-G3, Forte Spring 2017
CPSU-FORTE-S17S13G3
4 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 24
Ao todo: 5,702
