Ir para o conteúdo principal
SwagTron T1 Wheel Replacement
O que você precisa
  1. SwagTron T1 Wheel Replacement, Back Panels: passo 1, imagem 1 %32
    • Ensure that the SwagTron is off.
    • Turn the SwagTron upside down to see the underside.
  2. SwagTron T1 Wheel Replacement: passo 2, imagem 1 %32 SwagTron T1 Wheel Replacement: passo 2, imagem 2 %32 SwagTron T1 Wheel Replacement: passo 2, imagem 3 %32
    • Unscrew the eighteen 10mm screws that secure the back panels using a Phillips #2 screwdriver.
    • The screws are tightly in place. It will take effort to screw them out.
    • The panel is still attached to the SwagTron by wires that go to the motherboard.
    • Carefully lift the panels off
  3. SwagTron T1 Wheel Replacement: passo 3, imagem 1 %32 SwagTron T1 Wheel Replacement: passo 3, imagem 2 %32 SwagTron T1 Wheel Replacement: passo 3, imagem 3 %32
    • Follow the wires from the panels to the motherboard.
    • You may need to cut any zip ties that are holding the wires together.
    • There is one connection on the battery side and three on the other side that must be removed.
    • These connections may be difficult to remove. Try to securely press the connection and pull firmly.
    • Your back panels are now completely removed.
  4. SwagTron T1 Wheel Replacement, Wheel: passo 4, imagem 1 %32 SwagTron T1 Wheel Replacement, Wheel: passo 4, imagem 2 %32 SwagTron T1 Wheel Replacement, Wheel: passo 4, imagem 3 %32
    • Using your Phillips #2 screwdriver, remove the four 1cm screws that attach the gyroscope and its black case to the hoverboard.
    • Carefully remove this component and set it off to the side.
  5. SwagTron T1 Wheel Replacement: passo 5, imagem 1 %32 SwagTron T1 Wheel Replacement: passo 5, imagem 2 %32 SwagTron T1 Wheel Replacement: passo 5, imagem 3 %32
    • Using your H 6.0 allen wrench, remove the four 20mm black bolts shown in the picture.
    • Take off the iron plate holding the wheel in place.
    • Remove the Motor/Wheel and set it aside close by to the hoverboard.
    • The wires from the Motor/Wheel should still be connected to the motherboard.
    • These bolts are very tight, it may be difficult to remove them. Try using a tool with a long handle.
  6. SwagTron T1 Wheel Replacement: passo 6, imagem 1 %32 SwagTron T1 Wheel Replacement: passo 6, imagem 2 %32 SwagTron T1 Wheel Replacement: passo 6, imagem 3 %32
    • Slide the protective plastic off the connectors on the marked wires (green, blue, and yellow) using your hands or a set of tweezers.
    • The connectors on the wires of your hoverboard may be different from those shown in the pictures on the left due to differences in manufacturing.
    • Separate the set of marked green, blue, and yellow wires from their connectors.
  7. SwagTron T1 Wheel Replacement: passo 7, imagem 1 %32 SwagTron T1 Wheel Replacement: passo 7, imagem 2 %32 SwagTron T1 Wheel Replacement: passo 7, imagem 3 %32
    • Finally separate the last connector shown on the left.
    • Your wheel is completely removed; slide in a new Motor/Wheel into the slot and follow the previous steps in reverse order.
    • Make sure the replacement wheel is snug. Neither rubbing on the outer rim nor on the side of the hoverboard.
Conclusão
4 outras pessoas executaram este guia.
Teagan Allen
Membro desde: 04/18/17
426 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S17-G5, Banghart Spring 2017 Membro de Cal Poly, Team S17-G5, Banghart Spring 2017
CPSU-BANGHART-S17S17G5
Membros da 4
Autoria de 5 guias
3 comentários
Where do you get replacement wheels?
Elizabeth Schumacher - Responder
Where can we find replacement wheels?
Liz Vance - Responder
Mine won't stop beeping?? Fully charged.
Rachael Anderson - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 14
Últimos 30 dias: 26
Duração total: 5,624
