Ir para o conteúdo principal
Surfboard Traction Pad Replacement
O que você precisa
  1. Surfboard Traction Pad Replacement, Traction Pad: passo 1, imagem 1 %32 Surfboard Traction Pad Replacement, Traction Pad: passo 1, imagem 2 %32
    • Apply protective gloves.
  2. Surfboard Traction Pad Replacement: passo 2, imagem 1 %32 Surfboard Traction Pad Replacement: passo 2, imagem 2 %32 Surfboard Traction Pad Replacement: passo 2, imagem 3 %32
    • Pull up the traction pad from the surfboard.
    • This allows for an easy start to cutting the adhesive.
  3. Surfboard Traction Pad Replacement: passo 3, imagem 1 %32 Surfboard Traction Pad Replacement: passo 3, imagem 2 %32
    • Using a razor blade, cut away at the adhesive under the traction pad.
  4. Surfboard Traction Pad Replacement: passo 4, imagem 1 %32 Surfboard Traction Pad Replacement: passo 4, imagem 2 %32
    • Completely remove each section of the traction pad leaving only excess adhesive.
  5. Surfboard Traction Pad Replacement: passo 5, imagem 1 %32 Surfboard Traction Pad Replacement: passo 5, imagem 2 %32 Surfboard Traction Pad Replacement: passo 5, imagem 3 %32
    • Apply adhesive remover to the paper towels.
    • Apply the paper towels to the section of the board with excess adhesive until it is covered.
    • Let it stand for 5 minutes.
  6. Surfboard Traction Pad Replacement: passo 6, imagem 1 %32 Surfboard Traction Pad Replacement: passo 6, imagem 2 %32 Surfboard Traction Pad Replacement: passo 6, imagem 3 %32
    • Remove the paper towels from the board.
    • Cut away the rest of the excess adhesive.
    • Dry the board with paper towels.
Conclusão
Now the tail of your board is clean and ready for a new traction pad.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 11
Duração total: 406
