Introdução
This is a guide on how to replace the battery in a Microsoft Surface Laptop Studio. You may need to replace your battery if your device is unresponsive and won't turn on after charging it, or if battery life is short. You will only need a few tools for the repair and it only takes 10-15 minutes.
O que você precisa
Disconnect the battery cable by lifting the pull tab until it "clicks."
Pull the pull tabs to release the adhesive securing the battery.
Remove the battery.
To reassemble your device, follow the instructions in reverse order.
Uma outra pessoa concluiu este guia.
3 comentários
Where can I find a Surface Studio Laptop battery? Microsoft seems to have been out of stock for a while now.
Are the rubber feet re-attachable to the laptop after repairs?
Any link to buy the battery ?
