Ir para o conteúdo principal
Supersonic Matrix SC-91MID Screen Replacement
O que você precisa
  1. Supersonic Matrix SC-91MID Screen Replacement, Screen: passo 1, imagem 1 %32 Supersonic Matrix SC-91MID Screen Replacement, Screen: passo 1, imagem 2 %32
    • Place the plastic opening tool between the screen and the main component and pry open between the two. Once removed place the main component in a safe place and continue working on the screen section (highlighted in red).
    • Be aware of the wires when removing the display screen from the main component (highlighted in orange)
  2. Supersonic Matrix SC-91MID Screen Replacement: passo 2, imagem 1 %32 Supersonic Matrix SC-91MID Screen Replacement: passo 2, imagem 2 %32 Supersonic Matrix SC-91MID Screen Replacement: passo 2, imagem 3 %32
    • Place the plastic opening tool between the metal screen plate and the black front casing.
    • There are small clips where the plastic opening tool can be placed to help pry the screen from the casing.
  3. Supersonic Matrix SC-91MID Screen Replacement: passo 3, imagem 1 %32 Supersonic Matrix SC-91MID Screen Replacement: passo 3, imagem 2 %32 Supersonic Matrix SC-91MID Screen Replacement: passo 3, imagem 3 %32
    • Continue to slide the opening tool along the length of the casing until there is a clear separation between the screen and the cover (as shown in the third image).
  4. Supersonic Matrix SC-91MID Screen Replacement: passo 4, imagem 1 %32
    • Once there is a clearing, carefully remove the screen from the black cover. You now have separated the screen from the tablet device and and are now ready to replace screen.
Conclusão
Uma outra pessoa concluiu este guia.
Norikuni Nishikawa
Membro desde: 03/31/18
139 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team S1-G1, Wilson Spring 2018 Membro de IUPUI, Team S1-G1, Wilson Spring 2018
IUPUI-WILSON-S18S1G1
Membros da 5
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 266
