O que você precisa
Remove the six screws located on the underside of the system using the Gamebit 4.5mm screwdriver.
Remove the two 11.7 mm Phillips #2 screws connecting the power switch to the motherboard.
Lift the controller ports out of the housing, this should be done without much force. Take note of the location of the ribbon cable connection.
Remove the two Phillips two 11.6mm screws that connect the front shield to the motherboard.
44 outras pessoas executaram este guia.
4 comentários
There are several versions of the Super Nintendo. Steps for my version are a bit different.
This seems to be a newer super nintendo. If you have one of the older ones, there will be a bit more screws but still basically the same steps.
There are two versions of the Super Nintendo- the one pictured here, and one with a sound chip board behind the game cartridge reader. These two models have different shells that are not interchangeable (important to know if you're looking to buy a replacement housing for your SNES)
Gena FM -
It’s possible they may be referring to the European/Japanese version of the Super Nintendo/Super Famicom. Either that, or it’s one of the weird, misshapen “reskins”.
