Ir para o conteúdo principal
Sungale CyberUs Screen Replacement
O que você precisa
  1. Sungale CyberUs Screen Replacement, Screen: passo 1, imagem 1 %32
    • Make sure to have the device turned off to prevent any minor electric shock.
    • Hold the device so the left side is facing towards you (like in the picture shown) so the two 4mm PH001 screws are exposed and easier to access.
  2. Sungale CyberUs Screen Replacement: passo 2, imagem 1 %32
    • Remove both 4mm PH001 screws from the side panel.
  3. Sungale CyberUs Screen Replacement: passo 3, imagem 1 %32 Sungale CyberUs Screen Replacement: passo 3, imagem 2 %32
    • Carefully pry up one of the top corners of the screen with a plastic spudger (prying tool). Slide the tool along the edges to release it from the housing.
    • The screen may make some cracking noises as you pry it from the casing. This is expected.
    • The screen is still connected to the motherboard. Use force with caution.
  4. Sungale CyberUs Screen Replacement: passo 4, imagem 1 %32
    • Gently turn screen over, to the side, to reveal the ZIF connector attached to the motherboard.
  5. Sungale CyberUs Screen Replacement: passo 5, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Gently using tweezers, flip the black clip up. Pull the ZIF connector out.
    • You screen is still not completely detached from the device.
  6. Sungale CyberUs Screen Replacement: passo 6, imagem 1 %32 Sungale CyberUs Screen Replacement: passo 6, imagem 2 %32
    • Using the prying tool, slide the black clip out. Pull the ZIF connector out and to the left, the screen is now detached from the motherboard.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
IUPUI, Team 1-4, Harley Fall 2016 Membro de IUPUI, Team 1-4, Harley Fall 2016
IUPUI-HARLEY-F16S1G4
Membros da 3
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Duração total: 141
