Ir para o conteúdo principal
Sun King Solo Solar Lantern Device Seals Replacement
O que você precisa
  1. Sun King Solo Solar Lantern Device Seals Replacement, Locate and Remove the Screws: passo 1, imagem 1 %32
    • Place the lamp LED side down on a clean workspace.
    • Remove the screws holding the casing together using a Phillips #1 Screwdriver.
  2. Sun King Solo Solar Lantern Device Seals Replacement, Separate the Device: passo 2, imagem 1 %32
    • Gently pull the two halves of the lamp apart.
  3. Sun King Solo Solar Lantern Device Seals Replacement, O-ring Replacement: passo 3, imagem 1 %32 Sun King Solo Solar Lantern Device Seals Replacement, O-ring Replacement: passo 3, imagem 2 %32
    • On the clear upper half, remove the black O-ring
    • Place the new O-ring, making sure it is smooth all the way around
  4. Sun King Solo Solar Lantern Device Seals Replacement, Stand Holder Replacements: passo 4, imagem 1 %32
    • Remove the rubber stand holders.
    • Place the new stand holders, making sure the wings of the holder are in the second opening
Conclusão
Josef Simek
Membro desde: 10/23/14
132 Reputação
Autoria de 1 guia
Equipe
Michigan Tech, Team 1-3, Lauer Fall 2014 Membro de Michigan Tech, Team 1-3, Lauer Fall 2014
MTU-LAUER-F14S1G3
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 7
Duração total: 495
