Ir para o conteúdo principal
Sun King Solo Solar Lantern Battery Replacement
O que você precisa
  1. Sun King Solo Solar Lantern Battery Replacement, Locate and Remove the Screws: passo 1, imagem 1 %32
    • Place the lamp LED side down on a clean workspace.
    • Remove the screws holding the casing together using a Phillips #1 Screwdriver.
  2. Sun King Solo Solar Lantern Battery Replacement, Separate the Device: passo 2, imagem 1 %32
    • Gently pull the two halves of the lamp apart.
  3. Sun King Solo Solar Lantern Battery Replacement, Isolate the Battery: passo 3, imagem 1 %32 Sun King Solo Solar Lantern Battery Replacement, Isolate the Battery: passo 3, imagem 2 %32
    • Locate the battery.
    • Gently lift the battery from the device.
  4. Sun King Solo Solar Lantern Battery Replacement, Remove the Battery: passo 4, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Locate the clip attaching the battery pack to the circuit board.
    • Use tweezers to remove the portion of the clip attached to the battery.
    • Do not pull directly on the wires! They can easily be damaged.
  5. Sun King Solo Solar Lantern Battery Replacement, Replace the Battery: passo 5, imagem 1 %32
    • Align the black wire of the new battery towards the center of the device.
    • Press down firmly on the clip to insure that it is properly connected.
    • Properly dispose of the Lithium-Ion Battery. Lithium Battery Disposal
  6. Sun King Solo Solar Lantern Battery Replacement, Reseat the Battery: passo 6, imagem 1 %32
    • Seat the battery in the orange component so that the short end of the battery pack is touching the foam bumper.
Conclusão
6 outras pessoas executaram este guia.
Anna
Membro desde: 10/23/14
613 Reputação
Autoria de 4 guias
Equipe
Michigan Tech, Team 1-3, Lauer Fall 2014 Membro de Michigan Tech, Team 1-3, Lauer Fall 2014
MTU-LAUER-F14S1G3
3 Membros
Autoria de 10 guias
8Comentários do guia
please help in finding the life p04 battery,3.2v ,1500 mah,batch #20309
SHARATH PONUGOTI - Responder Compartilhar
as my solar lights battery is dead..iam unable to find out whr i will get a new one
where to get the battery spare part?
johnkoisasi - Responder Compartilhar
Please help me in finding PRO sunking battery 6.6v,1450mAh, Batch 30130.
Please contact me:stanleymayor944@yahoo.com
Stanley - Responder Compartilhar
Howi can get 6.6 v sunking pro battery?please help me.
kapildeo mandal - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 28
Últimos 30 dias: 99
Ao todo: 5,488
