Essa tradução foi gerada por um programa e ainda não foi revisada por uma pessoa. Falas essa língua? Dá uma olhada.
Introdução
Ir para o passo 1 ↓O Microsoft Surface Pro 4 vem equipado com um SSD M.2 da Samsung. Veja como substituí-lo caso ele falhe ou se você quiser fazer um upgrade.
O que você precisa
Use uma ferramenta de abertura de plástico azul para fazer alavanca ao redor das bordas da blindagem metálica que cobre a unidade SSD.
Remova o parafuso Torx T4 de 1,0 mm que prende a unidade SSD.
Para a remontagem de seu dispositivo, siga estas instruções na ordem inversa.
93 outras pessoas executaram este guia.
46Comentários do guia
Can you add more SSD to the SP4??
Where can I buy a 1T that is compatible with it?
You can probably replace it with any 1TB NVMe M.2 SSD you find at any retailer. You can find plenty of those on Amazon.
Tip: Look for the performance models, such as Samsung PRO or similar.
I would love to upgrade my storage while repairing my broken screen, does anyone know of which sdd would be compatible with my i7 8gb ram 256ssd right now? Does it have to be a samsung ssd or are there other options. Fairly new to computer repair here so would love some experienced advice thanks !
I would prefer a 1TB if possible but would settle for a 512 also.
@bthorne As long as it's the same connection (not sure, but maybe you should look for NVMe M.2 SSD) it should work without problems. You should run a quick search on the internet to check if anyone has found some sort of "blacklisted" parts (some vendors such as Lenovo used to place some code in their firmware which would prevent the computer from booting with a "unauthorized" wireless card for example.).
However I think this is not the case with the Surface Pro 4 or the world would be at rage right now. Just look for any size NVMe M.2 SSD you think it would be fit (if you can afford, look for performance models such as Samsung PRO, there's a huge difference from the cheaper ones.). Hope it helps!
