Ir para o conteúdo principal
Stuck Shutter Fix Replacement
  1. Stuck Shutter Fix  Replacement, Shutter: passo 1, imagem 1 %32
    • Put the camera in any mode other than Auto, and turn off the flash.
    • Turn off the LCD screen and press the DISP or DISPLAY button.
  2. Stuck Shutter Fix  Replacement, Adjust the Camera Setting: passo 2, imagem 1 %32
    • For many canon cameras this will be shutter priority mode, that will give you the longest exposure time without flash.
  3. Stuck Shutter Fix  Replacement, Open/Close the Battery Door: passo 3, imagem 1 %32
    • After a few seconds open the battery door then close it again. This will momentarily interrupt power during the exposure time.
    • Repeat the procedure until the shutter becomes unstuck.
Conclusão
Uma outra pessoa concluiu este guia.
Marina Bayardo
Membro desde: 10/22/15
233 Reputação
Autoria de 2 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 32
Últimos 30 dias: 131
Duração total: 6,730
