Introdução
This guide will demonstrate how to remove and replace a broken or bent arm of a Straight Leg Canopy Tent. There are 16 individual arms that allow for the tent to fully extend and open. Prior-knowledge skills useful to complete this task would be how to properly use a Phillips screwdriver and a wrench. Before starting this fix, the canopy cover should be removed for easy access of the joints and the tent should be standing and opened.
O que você precisa
Use the wrench to hold the nut in place.
Use the Phillips screwdriver to unscrew the screw.
After following these instructions in chronological order, the end result would be for the successful removal and replacement of an arm on a Straight Leg Canopy Tent.
Uma outra pessoa concluiu este guia.
