Ir para o conteúdo principal
Steelseries Rival 700 Gaming Mouse Sensor Assemby Replacement
O que você precisa
  1. Steelseries Rival 700 Gaming Mouse Sensor Assemby Replacement, Disconnect the mouse from your computer: passo 1, imagem 1 %32 Steelseries Rival 700 Gaming Mouse Sensor Assemby Replacement, Disconnect the mouse from your computer: passo 1, imagem 2 %32
    • To avoid electronically damaging either your computer or your mouse, unplug the usb cable from its socket.
  2. Steelseries Rival 700 Gaming Mouse Sensor Assemby Replacement, Disconnect the cable from the mouse: passo 2, imagem 1 %32 Steelseries Rival 700 Gaming Mouse Sensor Assemby Replacement, Disconnect the cable from the mouse: passo 2, imagem 2 %32 Steelseries Rival 700 Gaming Mouse Sensor Assemby Replacement, Disconnect the cable from the mouse: passo 2, imagem 3 %32
    • The Rival 700 mouse is a non wireless mouse. The micro-USB cable end is an elbow socket, secured by a plastic clip.
    • To disconnect the cable from the mouse, firmly press the plastic clip using your thumb
  3. Steelseries Rival 700 Gaming Mouse Sensor Assemby Replacement, Nameplate removal: passo 3, imagem 1 %32 Steelseries Rival 700 Gaming Mouse Sensor Assemby Replacement, Nameplate removal: passo 3, imagem 2 %32
    • The original nameplate is a soft rubber one that can be removed just by pulling it softly out of its socket.
    • WARNING: When reassembling, if you're using a custom nameplate that may not be as stretchable as the original one, insert it softly, and use a lime tool on the new part to avoid damaging the mouse socket.
  4. Steelseries Rival 700 Gaming Mouse Sensor Assemby Replacement, Nameplate printing: passo 4, imagem 1 %32
    • You will be able to download the 3D files to design a custom nameplate on the Steelseries website. The link is also provided in the part description.
    • On this picture, the original "RIVAL" nameplate will be replaced with a new one on which i just had my Twitch ID printed.
    • Be creative, use colored plastic, put logos and drawings on your mouse.
  5. Steelseries Rival 700 Gaming Mouse Sensor Assemby Replacement, Top cover removal: passo 5, imagem 1 %32 Steelseries Rival 700 Gaming Mouse Sensor Assemby Replacement, Top cover removal: passo 5, imagem 2 %32 Steelseries Rival 700 Gaming Mouse Sensor Assemby Replacement, Top cover removal: passo 5, imagem 3 %32
    • Use both your index and thumb to gently pry the top cover out from the mouse.
    • This part is a thin plastic one which needs a certain amount of strength to be removed. Be careful not to break it.
  6. Steelseries Rival 700 Gaming Mouse Sensor Assemby Replacement, Top cover replacement: passo 6, imagem 1 %32
    • Steelseries sells a set of two different covers to replace the original one, with a sweat-resistant one f.e.
    • Check the parts section for the purchase link.
    • On the left, you can see on the wide led slot that is used to color the Steelseries logo on your mouse.
  7. Steelseries Rival 700 Gaming Mouse Sensor Assemby Replacement, Sensor screws: passo 7, imagem 1 %32 Steelseries Rival 700 Gaming Mouse Sensor Assemby Replacement, Sensor screws: passo 7, imagem 2 %32
    • Use a Philips #0 screwdriver to remove the four screws that are keeping the mouse sensor assembly sealed.
  8. Steelseries Rival 700 Gaming Mouse Sensor Assemby Replacement, Sensor removal: passo 8, imagem 1 %32
    • Insert your thumb and index in the two mouse holes and gently pry the sensor assembly out from its socket.
Conclusão
3 outras pessoas executaram este guia.
Vincent Monteil
Membro desde: 07/06/13
6.975 Reputação
Autoria de 19 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 13
Duração total: 1,703
