Ir para o conteúdo principal
Steelseries Rival 3 Scroll Wheel Replacement
O que você precisa
  1. Steelseries Rival 3 Scroll Wheel Replacement, Scroll Wheel: passo 1, imagem 1 %32
    • Disconnect the mouse from your laptop/personal computer.
  2. Steelseries Rival 3 Scroll Wheel Replacement: passo 2, imagem 1 %32 Steelseries Rival 3 Scroll Wheel Replacement: passo 2, imagem 2 %32
    • Remove the three mouse skates with a prying tool.
    • Your prying tool may slip when removing the skates so proceed with caution.
    • If new skates are needed, purchase them at SteelSeries Rival 3 Mouse Skates.
  3. Steelseries Rival 3 Scroll Wheel Replacement: passo 3, imagem 1 %32
    • Use a Phillips #0 screwdriver to remove the four screws from the base of the mouse and remove the casing.
  4. Steelseries Rival 3 Scroll Wheel Replacement: passo 4, imagem 1 %32
    • Remove the wire that is connected to the circuit board of the mouse as shown in the image.
    • The wire and the socket can be damaged if not handled with care.
  5. Steelseries Rival 3 Scroll Wheel Replacement: passo 5, imagem 1 %32
    • Carefully take off the circuit board and lay it on the surface being used.
    • Be careful when doing so to prevent the wire connected to the base of the mouse from breaking.
  6. Steelseries Rival 3 Scroll Wheel Replacement: passo 6, imagem 1 %32 Steelseries Rival 3 Scroll Wheel Replacement: passo 6, imagem 2 %32
    • Remove the four black screws along the circuit board using a Phillips #0 screwdriver.
  7. Steelseries Rival 3 Scroll Wheel Replacement: passo 7, imagem 1 %32
    • Remove the scroll wheel by taking it out of its socket.
    • The socket is the silver tower that allows the mouse to turn while keeping the scroll wheel stiff.
  8. Steelseries Rival 3 Scroll Wheel Replacement: passo 8, imagem 1 %32
    • Insert your new scroll wheel into the tower where the scroll wheel was originally.
    • Ensure not to apply excessive force during the process.
    • Before you put the mouse back together, make sure the scroll wheel turns smoothly in order for the mouse to work.
Conclusão
Uma outra pessoa concluiu este guia.
Noah Perlmutar
Membro desde: 01/17/24
157 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 32
Últimos 30 dias: 108
Duração total: 176
