Introdução
If your SteelSeries Stratus XL is having issues with it’s L2 or R2 trigger, use this guide to allow proper function to your controller.
Your controller triggers are activated with a spring and a screw from an arm pot together on the inside. You may need to do some minor adjustments to the screw on the inside along with some lubing using some isopropyl alcohol for the arm socket.
Be sure to fully disconnect and power off your controller before starting your work.
O que você precisa
Remove the battery cover and the batteries from the controller.
To reassemble your device, follow the instructions in reverse order.
1Comentário do guia
Can't believe this actually worked! The quality of construction is dispicably poor, the cable had melted onto the trigger springs or something, I've never seen such shoddy construction in my life. I picked out the red plastic gunk and turned the screw as advised. It was a little lower in the frame in my case so hard to reach with the flathead, but with a little perseverance I managed to twist it anti-clockwise and I no longer get phantom presses on my trigger. Many thanks!
