Ir para o conteúdo principal
SteelSeries Nimbus+ Triggers Replacement
O que você precisa
  1. SteelSeries Nimbus+ Triggers Replacement, Remove the phone mount: passo 1, imagem 1 %32 SteelSeries Nimbus+ Triggers Replacement, Remove the phone mount: passo 1, imagem 2 %32
    • Use your fingers to remove the phone mount by pulling it straight out of the controller.
  2. SteelSeries Nimbus+ Triggers Replacement, Remove the sticker: passo 2, imagem 1 %32
    • Use your fingers to remove the sticker located on the back cover of the Nimbus+.
    • If you have trouble removing the sticker heat an iOpener and apply it to the rear case for two minutes to loosen the adhesive underneath.
  3. SteelSeries Nimbus+ Triggers Replacement, Unscrew the back cover: passo 3, imagem 1 %32
    • Use a Y1 Tri-point screwdriver to remove the five 9.1 mm-long screws securing the back cover.
  4. SteelSeries Nimbus+ Triggers Replacement, Insert an opening pick: passo 4, imagem 1 %32 SteelSeries Nimbus+ Triggers Replacement, Insert an opening pick: passo 4, imagem 2 %32
    • The back cover is held in place by plastic clips.
    • Insert an opening pick into the gap between the front and back cover assembly at the outside of the right controller handle.
  5. SteelSeries Nimbus+ Triggers Replacement, Release the plastic clips: passo 5, imagem 1 %32 SteelSeries Nimbus+ Triggers Replacement, Release the plastic clips: passo 5, imagem 2 %32
    • Slide the opening pick to the top of the controller to release the remaining plastic clips on the right edge.
  6. SteelSeries Nimbus+ Triggers Replacement, Insert an opening pick: passo 6, imagem 1 %32 SteelSeries Nimbus+ Triggers Replacement, Insert an opening pick: passo 6, imagem 2 %32
    • Insert an opening pick into the gap between the front and back cover assembly at the outside of the left controller handle.
  7. SteelSeries Nimbus+ Triggers Replacement, Release the plastic clips: passo 7, imagem 1 %32 SteelSeries Nimbus+ Triggers Replacement, Release the plastic clips: passo 7, imagem 2 %32
    • Slide the opening pick to the top of the controller to release the remaining plastic clips on the left edge.
  8. SteelSeries Nimbus+ Triggers Replacement, Unfold the back cover assembly: passo 8, imagem 1 %32 SteelSeries Nimbus+ Triggers Replacement, Unfold the back cover assembly: passo 8, imagem 2 %32 SteelSeries Nimbus+ Triggers Replacement, Unfold the back cover assembly: passo 8, imagem 3 %32
    • Carefully fold the back cover assembly to the top of the SteelSeries Nimbus+ and bring it in an 90 degree angle.
    • Do not try to remove the back cover assembly all the way yet! It is still connected to mainboard.
  9. SteelSeries Nimbus+ Triggers Replacement, Disconnect the battery cable: passo 9, imagem 1 %32 SteelSeries Nimbus+ Triggers Replacement, Disconnect the battery cable: passo 9, imagem 2 %32 SteelSeries Nimbus+ Triggers Replacement, Disconnect the battery cable: passo 9, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Use a pair of blunt nose tweezers to disconnect the battery cable from the mainboard.
  10. SteelSeries Nimbus+ Triggers Replacement, Remove the back cover assembly: passo 10, imagem 1 %32
    • Remove the back cover assembly.
  11. SteelSeries Nimbus+ Triggers Replacement, Unscrew the board: passo 11, imagem 1 %32
    • Use a Phillips screwdriver to remove the two 7.0 mm-long screws securing the board.
  12. SteelSeries Nimbus+ Triggers Replacement, Disconnect the thumbstick board: passo 12, imagem 1 %32 SteelSeries Nimbus+ Triggers Replacement, Disconnect the thumbstick board: passo 12, imagem 2 %32 SteelSeries Nimbus+ Triggers Replacement, Disconnect the thumbstick board: passo 12, imagem 3 %32
    • Disconnect the thumbstick board by pulling it straight out its socket on the mainboard.
  13. SteelSeries Nimbus+ Triggers Replacement, Remove the board: passo 13, imagem 1 %32
    • Remove the board with the thumbsticks from the mainboard.
  14. SteelSeries Nimbus+ Triggers Replacement, Unscrew the mainboard: passo 14, imagem 1 %32
    • Use a Phillips screwdriver to remove the five 7.0 mm-long screws securing the mainboard to the front assembly.
  15. SteelSeries Nimbus+ Triggers Replacement, Lift up the mainboard: passo 15, imagem 1 %32 SteelSeries Nimbus+ Triggers Replacement, Lift up the mainboard: passo 15, imagem 2 %32 SteelSeries Nimbus+ Triggers Replacement, Lift up the mainboard: passo 15, imagem 3 %32
    • Use your fingers to lift up the mainboard from the front case.
    • Remove the mainboard.
  16. SteelSeries Nimbus+ Triggers Replacement, Unscrew the triggers: passo 16, imagem 1 %32
    • Use a Phillips screwdriver to remove the four 7.0 mm screws securing the triggers on the motherboard.
  17. SteelSeries Nimbus+ Triggers Replacement, Release the right trigger: passo 17, imagem 1 %32 SteelSeries Nimbus+ Triggers Replacement, Release the right trigger: passo 17, imagem 2 %32
    • Pull the right trigger straight out to slide it off of the rails securing it to the button connector on the motherboard.
  18. SteelSeries Nimbus+ Triggers Replacement, Release the left trigger: passo 18, imagem 1 %32 SteelSeries Nimbus+ Triggers Replacement, Release the left trigger: passo 18, imagem 2 %32
    • Pull the left trigger straight out to slide it off of the rails securing it to the button connector on the motherboard.
Conclusão
Adriana Zwink
Membro desde: 12/18/19
61.760 Reputação
Autoria de 167 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 23.608 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 10
Ao todo: 422
