Ir para o conteúdo principal
SteelSeries Nimbus+ Mainboard Replacement
O que você precisa
  1. SteelSeries Nimbus+ Mainboard Replacement, Remove the phone mount: passo 1, imagem 1 %32 SteelSeries Nimbus+ Mainboard Replacement, Remove the phone mount: passo 1, imagem 2 %32
    • Use your fingers to remove the phone mount by pulling it straight out of the controller.
  2. SteelSeries Nimbus+ Mainboard Replacement, Remove the sticker: passo 2, imagem 1 %32
    • Use your fingers to remove the sticker located on the back cover of the Nimbus+.
    • If you have trouble removing the sticker heat an iOpener and apply it to the rear case for two minutes to loosen the adhesive underneath.
  3. SteelSeries Nimbus+ Mainboard Replacement, Unscrew the back cover: passo 3, imagem 1 %32
    • Use a Y1 Tri-point screwdriver to remove the five 9.1 mm-long screws securing the back cover.
  4. SteelSeries Nimbus+ Mainboard Replacement, Insert an opening pick: passo 4, imagem 1 %32 SteelSeries Nimbus+ Mainboard Replacement, Insert an opening pick: passo 4, imagem 2 %32
    • The back cover is held in place by plastic clips.
    • Insert an opening pick into the gap between the front and back cover assembly at the outside of the right controller handle.
  5. SteelSeries Nimbus+ Mainboard Replacement, Release the plastic clips: passo 5, imagem 1 %32 SteelSeries Nimbus+ Mainboard Replacement, Release the plastic clips: passo 5, imagem 2 %32
    • Slide the opening pick to the top of the controller to release the remaining plastic clips on the right edge.
  6. SteelSeries Nimbus+ Mainboard Replacement, Insert an opening pick: passo 6, imagem 1 %32 SteelSeries Nimbus+ Mainboard Replacement, Insert an opening pick: passo 6, imagem 2 %32
    • Insert an opening pick into the gap between the front and back cover assembly at the outside of the left controller handle.
  7. SteelSeries Nimbus+ Mainboard Replacement, Release the plastic clips: passo 7, imagem 1 %32 SteelSeries Nimbus+ Mainboard Replacement, Release the plastic clips: passo 7, imagem 2 %32
    • Slide the opening pick to the top of the controller to release the remaining plastic clips on the left edge.
  8. SteelSeries Nimbus+ Mainboard Replacement, Unfold the back cover assembly: passo 8, imagem 1 %32 SteelSeries Nimbus+ Mainboard Replacement, Unfold the back cover assembly: passo 8, imagem 2 %32 SteelSeries Nimbus+ Mainboard Replacement, Unfold the back cover assembly: passo 8, imagem 3 %32
    • Carefully fold the back cover assembly to the top of the SteelSeries Nimbus+ and bring it in an 90 degree angle.
    • Do not try to remove the back cover assembly all the way yet! It is still connected to mainboard.
  9. SteelSeries Nimbus+ Mainboard Replacement, Disconnect the battery cable: passo 9, imagem 1 %32 SteelSeries Nimbus+ Mainboard Replacement, Disconnect the battery cable: passo 9, imagem 2 %32 SteelSeries Nimbus+ Mainboard Replacement, Disconnect the battery cable: passo 9, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Use a pair of blunt nose tweezers to disconnect the battery cable from the mainboard.
  10. SteelSeries Nimbus+ Mainboard Replacement, Remove the back cover assembly: passo 10, imagem 1 %32
    • Remove the back cover assembly.
  11. SteelSeries Nimbus+ Mainboard Replacement, Unscrew the board: passo 11, imagem 1 %32
    • Use a Phillips screwdriver to remove the two 7.0 mm-long screws securing the board.
  12. SteelSeries Nimbus+ Mainboard Replacement, Disconnect the thumbstick board: passo 12, imagem 1 %32 SteelSeries Nimbus+ Mainboard Replacement, Disconnect the thumbstick board: passo 12, imagem 2 %32 SteelSeries Nimbus+ Mainboard Replacement, Disconnect the thumbstick board: passo 12, imagem 3 %32
    • Disconnect the thumbstick board by pulling it straight out its socket on the mainboard.
  13. SteelSeries Nimbus+ Mainboard Replacement, Remove the board: passo 13, imagem 1 %32
    • Remove the board with the thumbsticks from the mainboard.
  14. SteelSeries Nimbus+ Mainboard Replacement, Unscrew the mainboard: passo 14, imagem 1 %32
    • Use a Phillips screwdriver to remove the five 7.0 mm-long screws securing the mainboard to the front assembly.
  15. SteelSeries Nimbus+ Mainboard Replacement, Lift up the mainboard: passo 15, imagem 1 %32 SteelSeries Nimbus+ Mainboard Replacement, Lift up the mainboard: passo 15, imagem 2 %32 SteelSeries Nimbus+ Mainboard Replacement, Lift up the mainboard: passo 15, imagem 3 %32
    • Use your fingers to lift up the mainboard from the front case.
    • Remove the mainboard.
  16. SteelSeries Nimbus+ Mainboard Replacement, Unscrew the triggers: passo 16, imagem 1 %32
    • Use a Phillips screwdriver to remove the four screws securing the triggers on the motherboard.
  17. SteelSeries Nimbus+ Mainboard Replacement, Release the right trigger: passo 17, imagem 1 %32 SteelSeries Nimbus+ Mainboard Replacement, Release the right trigger: passo 17, imagem 2 %32
    • Pull the right trigger straight out to slide it off of the rails securing it to the button connector on the motherboard.
  18. SteelSeries Nimbus+ Mainboard Replacement, Release the left trigger: passo 18, imagem 1 %32 SteelSeries Nimbus+ Mainboard Replacement, Release the left trigger: passo 18, imagem 2 %32
    • Pull the left trigger straight out to slide it off of the rails securing it to the button connector on the motherboard.
  19. SteelSeries Nimbus+ Mainboard Replacement, Remove the mainboard: passo 19, imagem 1 %32
    • Compare your new mainboard with the original mainboard. It may be necessary to transfer over some components. For this, you may have to unsolder the trigger buttons or attach the rubber covers to the new mainboard.
Conclusão
Adriana Zwink
Membro desde: 12/18/19
61.760 Reputação
Autoria de 167 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 23.608 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 13
Ao todo: 347
