Introdução
If the headset mute button is broken or not pressing down properly, follow this guide to replace the button cap.
O que você precisa
Lift the edge of the cushion and pull out slightly.
Work your way around the cushion until it comes off completely.
Repeat for the other cushion.
Remove the three 5mm screws with a Phillips #0 driver head on the headphone with the microphone.
Flip the circuit board over and remove the keycap by pulling on it.
5 outras pessoas executaram este guia.
