Ir para o conteúdo principal
SteelSeries Arctis Pro Plus GameDAC Headset Circuit Board Replacement
O que você precisa
  1. SteelSeries Arctis Pro Plus GameDAC Headset Circuit Board Replacement, Headset Ear Cushions: passo 1, imagem 1 %32 SteelSeries Arctis Pro Plus GameDAC Headset Circuit Board Replacement, Headset Ear Cushions: passo 1, imagem 2 %32
    • Lift the edge of the cushion and pull out slightly.
    • Work your way around the cushion until it comes off completely.
    • Repeat for the other cushion.
  2. SteelSeries Arctis Pro Plus GameDAC Headset Circuit Board Replacement, Headset Circuit Board: passo 2, imagem 1 %32
    • Remove the three 5mm screws with a Phillips #0 driver head on the headphone with the microphone.
  3. SteelSeries Arctis Pro Plus GameDAC Headset Circuit Board Replacement: passo 3, imagem 1 %32
    • Lift the speaker off the headset to expose the circuit board.
    • Be careful not to lift the speaker too quickly or too forcefully to prevent the wires from being pulled out of their connections.
  4. SteelSeries Arctis Pro Plus GameDAC Headset Circuit Board Replacement: passo 4, imagem 1 %32
    • Remove the three 5mm screws using a Phillips #0 driver head.
  5. SteelSeries Arctis Pro Plus GameDAC Headset Circuit Board Replacement: passo 5, imagem 1 %32
    • Lift the circuit board out of the plastic housing.
    • Press in on the volume wheel while pulling on the circuit board to help maneuver the circuit board out of the housing.
Conclusão
7 outras pessoas executaram este guia.
Kyle Chang
Membro desde: 01/24/19
1.152 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team S18-G1, White Winter 2019 Membro de Cal Poly, Team S18-G1, White Winter 2019
CPSU-WHITE-W19S18G1
Membros da 4
Autoria de 21 guias
3 comentários
any idea where i can buy the circuit parts to both side?
erminio santiago - Responder
any idea where i can buy Circuit Board Replacement for both side? please
What's the problem that requires circuit board replacement? My left speaker doesn't work checked and all wires connected. Wondering if the circuit board fixes that
bayarea_rooter - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 12
Últimos 30 dias: 89
Duração total: 9,204
