Ir para o conteúdo principal
SteelSeries Arctis Pro Microphone Cable Replacement
O que você precisa
  1. SteelSeries Arctis Pro Microphone Cable Replacement, Microphone Cable: passo 1, imagem 1 %32 SteelSeries Arctis Pro Microphone Cable Replacement, Microphone Cable: passo 1, imagem 2 %32
    • Remove ear cushion by pulling the cushion up and towards yourself.
    • Repeat this motion around the cushion until it comes free.
  2. SteelSeries Arctis Pro Microphone Cable Replacement: passo 2, imagem 1 %32 SteelSeries Arctis Pro Microphone Cable Replacement: passo 2, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove the 3 case screws.
    • Lift the driver assembly away from the rest of the housing.
  3. SteelSeries Arctis Pro Microphone Cable Replacement: passo 3, imagem 1 %32 SteelSeries Arctis Pro Microphone Cable Replacement: passo 3, imagem 2 %32 SteelSeries Arctis Pro Microphone Cable Replacement: passo 3, imagem 3 %32
    • Use a Phillips #0 screwdriver to remove the three 5 mm screws.
    • Push the headset volume dial in-words towards the housing while simultaneously pulling the board towards yourself.
  4. SteelSeries Arctis Pro Microphone Cable Replacement: passo 4, imagem 1 %32
    • De-solder the six connections on the side of the main board.
  5. SteelSeries Arctis Pro Microphone Cable Replacement: passo 5, imagem 1 %32
    • Use a Phillips #0 screwdriver to remove the two 5 mm screws that secure the microphone holder.
  6. SteelSeries Arctis Pro Microphone Cable Replacement: passo 6, imagem 1 %32 SteelSeries Arctis Pro Microphone Cable Replacement: passo 6, imagem 2 %32 SteelSeries Arctis Pro Microphone Cable Replacement: passo 6, imagem 3 %32
    • Pull the microphone assembly and cable out of the housing and out towards you until it comes free.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 8
Últimos 30 dias: 76
Duração total: 1,111
