Ir para o conteúdo principal
SteelSeries Arctis Pro Headset Mute Button Cap Replacement
O que você precisa
  1. SteelSeries Arctis Pro Headset Mute Button Cap Replacement, Headset Mute Button Cap: passo 1, imagem 1 %32 SteelSeries Arctis Pro Headset Mute Button Cap Replacement, Headset Mute Button Cap: passo 1, imagem 2 %32
    • Remove the ear cushion by pulling the edge up and towards yourself
    • Repeat this motion all the way around the ear cushion until it comes free
  2. SteelSeries Arctis Pro Headset Mute Button Cap Replacement: passo 2, imagem 1 %32 SteelSeries Arctis Pro Headset Mute Button Cap Replacement: passo 2, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove the 3 case screws.
    • Remove the driver assembly from the rest of the housing
  3. SteelSeries Arctis Pro Headset Mute Button Cap Replacement: passo 3, imagem 1 %32
    • Use a Phillips #0 screwdriver to remove the three 5 mm screws.
  4. SteelSeries Arctis Pro Headset Mute Button Cap Replacement: passo 4, imagem 1 %32 SteelSeries Arctis Pro Headset Mute Button Cap Replacement: passo 4, imagem 2 %32
    • Remove the circuit board by pushing the scroll wheel out of the board and pulling it from the other side.
  5. SteelSeries Arctis Pro Headset Mute Button Cap Replacement: passo 5, imagem 1 %32 SteelSeries Arctis Pro Headset Mute Button Cap Replacement: passo 5, imagem 2 %32
    • Grab the keycap and pull outwards till it comes free
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 14
Últimos 30 dias: 55
Duração total: 937
