Ir para o conteúdo principal
SteelSeries Apex 64145 USB Port Connector Replacement
O que você precisa
  1. SteelSeries Apex 64145 USB Port Connector Replacement, Gel Membrane: passo 1, imagem 1 %32
    • Unplug the keyboard from the computer.
  2. SteelSeries Apex 64145 USB Port Connector Replacement: passo 2, imagem 1 %32
    • Unscrew the twenty black 4.5 mm Phillips #1 screws on the back of the keyboard.
  3. SteelSeries Apex 64145 USB Port Connector Replacement: passo 3, imagem 1 %32
    • Pry open the back of the keyboard.
  4. SteelSeries Apex 64145 USB Port Connector Replacement: passo 4, imagem 1 %32 SteelSeries Apex 64145 USB Port Connector Replacement: passo 4, imagem 2 %32
    • Remove the gel membrane.
  5. SteelSeries Apex 64145 USB Port Connector Replacement, LED: passo 5, imagem 1 %32 SteelSeries Apex 64145 USB Port Connector Replacement, LED: passo 5, imagem 2 %32
    • Unscrew the two silver 4.0 mm Phillips #1 screws and the three black 6.5 mm Phillips #1 screws holding the silicone sheets.
  6. SteelSeries Apex 64145 USB Port Connector Replacement: passo 6, imagem 1 %32
    • Flip the chip slightly in order to remove the sheets.
  7. SteelSeries Apex 64145 USB Port Connector Replacement: passo 7, imagem 1 %32
    • Remove the sheets.
  8. SteelSeries Apex 64145 USB Port Connector Replacement: passo 8, imagem 1 %32 SteelSeries Apex 64145 USB Port Connector Replacement: passo 8, imagem 2 %32
    • Unscrew the two silver 4.5 mm Phillips #1 screws and the seven 5.0 mm Phillips #1 screws that deter the plastic panel from removal.
  9. SteelSeries Apex 64145 USB Port Connector Replacement: passo 9, imagem 1 %32
    • Remove the plastic panel and the white sheet.
  10. SteelSeries Apex 64145 USB Port Connector Replacement: passo 10, imagem 1 %32 SteelSeries Apex 64145 USB Port Connector Replacement: passo 10, imagem 2 %32 SteelSeries Apex 64145 USB Port Connector Replacement: passo 10, imagem 3 %32
    • Unplug the wires connected to the LEDs.
  11. SteelSeries Apex 64145 USB Port Connector Replacement: passo 11, imagem 1 %32 SteelSeries Apex 64145 USB Port Connector Replacement: passo 11, imagem 2 %32
    • Remove the LEDs.
  12. SteelSeries Apex 64145 USB Port Connector Replacement, USB Port Connector: passo 12, imagem 1 %32
    • Unscrew the two 4.5 mm silver Phillips #1 screws that hold the USB port connector.
  13. SteelSeries Apex 64145 USB Port Connector Replacement: passo 13, imagem 1 %32
    • Unplug the wires and remove the USB port connector.
Conclusão
Zwe Phone Shein
Membro desde: 02/28/17
559 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S1-G1, Nance Spring 2017 Membro de USF Tampa, Team S1-G1, Nance Spring 2017
USFT-NANCE-S17S1G1
Membros da 4
Autoria de 10 guias
2 comentários
the 2 usb in the keyboard what amp are they running on.. 500mA ? I hope for 1500-2000 mA
And what standard are they ? USB3 ??
Simon Sundström - Responder
can the other part be replaced too. like the power board ?
i think i have a powerboard problem and if I can replace it that would be awesome, as I love my keyboard and im
very very attached to it. I was playing a video game, nothing too harsh , and the lights went out and poof it never came back. never had a problem with this keyboard until 2 and a 1/2 years later that it did this. Its in a non-smoking room and gaming studio always kept very clean.
I would love to fix it to bring it back to life.
Twsted - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 15
Últimos 30 dias: 56
Duração total: 3,036
