Ir para o conteúdo principal
SteelSeries Apex 3 TKL USB Port Replacement
O que você precisa
  1. SteelSeries Apex 3 TKL USB Port Replacement, Back Panel: passo 1, imagem 1 %32
    • Use a JIS #00 screwdriver to remove all back panel screws.
  2. SteelSeries Apex 3 TKL USB Port Replacement: passo 2, imagem 1 %32 SteelSeries Apex 3 TKL USB Port Replacement: passo 2, imagem 2 %32
    • Use the iFixit opening pick to pry open the back panel by running it along the edges of the keyboard.
  3. SteelSeries Apex 3 TKL USB Port Replacement, USB Port: passo 3, imagem 1 %32
    • Release the ribbon wire connections using the metal spudger which has a more rigid tip for undoing the clips.
  4. SteelSeries Apex 3 TKL USB Port Replacement: passo 4, imagem 1 %32
    • Use a JIS #00 screwdriver to remove the USB port cover.
  5. SteelSeries Apex 3 TKL USB Port Replacement: passo 5, imagem 1 %32
    • Flip the motherboard over and carefully use the spudger to push out the connecting wire.
Conclusão
Use your new USB port insert back into the motherboard. To reassemble your device, follow these instructions in reverse order.
Tyler Pepe
Membro desde: 03/20/24
169 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 1-3, Santin Spring 2024 Membro de UMass Dartmouth, Team 1-3, Santin Spring 2024
UMASSD-SANTIN-S24S1G3
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 20
Duração total: 35
