Ir para o conteúdo principal
Steam Link Disassembly
O que você precisa
  1. Steam Link Disassembly, Starting up: passo 1, imagem 1 %32 Steam Link Disassembly, Starting up: passo 1, imagem 2 %32
    • Start by unplugging your device
    • Power cord
    • Ethernet
    • HDMI
    Pergunte ao FixBot
  2. Steam Link Disassembly, Removing the rubber bottom: passo 2, imagem 1 %32 Steam Link Disassembly, Removing the rubber bottom: passo 2, imagem 2 %32
    • Start by removing the rubber bottom using the Guitar Pick or the Jimmy
    • The first time, the adhesive may be difficult to remove
    Pergunte ao FixBot
  3. Steam Link Disassembly, Removing the screws: passo 3, imagem 1 %32 Steam Link Disassembly, Removing the screws: passo 3, imagem 2 %32
    • Remove the screws using a Torxx 6 bit
    Pergunte ao FixBot
  4. Steam Link Disassembly, Opening the lid: passo 4, imagem 1 %32 Steam Link Disassembly, Opening the lid: passo 4, imagem 2 %32
    • Open-up the bottom lid using guitar pics
    • The first time you open it, it might be difficult to open. Start by reaching the rounded, bottom-right corner
    Pergunte ao FixBot
  5. Steam Link Disassembly, Main board inspection: passo 5, imagem 1 %32 Steam Link Disassembly, Main board inspection: passo 5, imagem 2 %32
    • Marvel ArmV7 CPU
    • Vivante GC1000 GPU
    Pergunte ao FixBot
Conclusão
To reassemble your device, follow the steps in the opposite order
10 outras pessoas executaram este guia.
4Comentários do guia
bonjour esque cette carte peu servire comme raspberry merci
thesmoking gta - Responder Compartilhar
Non, seule une image signée par Valve peut être lancée. Elle a un accès SSH comme indiqué sur la page du SDK cependant. Notez qu'elle n'est plus fabriquée depuis décembre, donc elle n'est plus vraiment disponible.
Jorys Paulin (Jorys_Paulin) - Responder Compartilhar
Somewhat unworthy Teardown. Naming the CPU brand wrong and not giving any relevant information like schematics or ICs used. THIS is by far better: https://www.allaboutcircuits.com/news/te...
EDIT: Oh, it is a community post, sry. But more information would be nice. E.g. where is the massive heat sink? There are lots of parts missing.
Jan Seewald - Responder Compartilhar
Hello, this is my first (and only) teardown. I made it just for fun, really. I opened my Steam Link once and then decided to put it on the internet, because I found they weren’t that much photos of it around.
The heat sink is a large piece of aluminum, and now I realize I forgot to add it, my mistake.
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 19
Últimos 30 dias: 174
Ao todo: 7,752
