Ir para o conteúdo principal
O que você precisa
Vídeo de Apresentação
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Steam Deck, use o nosso manual de serviço.
    • Type 1: M1.6x9; plastic thread forming; 1.6 mm thread diameter; 0.64 mm thread pitch; 9 mm thread length; 2.8 mm head diameter; 0.6 mm head thickness
    • Type 2: M1.6x5; machine screw; 1.6 mm thread diameter; 0.35 mm thread pitch; 5 mm thread length; 2.8 mm head diameter; 0.5 mm head thickness
    • Type 3: M2x3.5; machine screw; 2 mm thread diameter; 0.4 mm thread pitch; 3.5 mm thread length; 5 mm head diameter; 0.9 mm head thickness
    • Type 4: M1.6x4.5; plastic thread forming; 1.6 mm thread diameter; 0.53 mm thread pitch; 4.5 mm thread length; 3.5 mm head diameter; 0.8 mm head thickness
    • Type 5: M1.6x3; machine screw; 1.6 mm thread diameter; 0.35 mm thread pitch; 3 mm thread length; 2.8 mm head diameter; 0.8 mm head thickness
    • Type 6: M2x2.2; machine screw; 2 mm thread diameter; 0.4 mm thread pitch; 2.2 mm thread length; 4.5 mm head diameter; 0.5 mm head thickness
    • Type 7: M1.6x4; plastic thread forming; 1.6 mm thread diameter; 0.53 mm thread pitch; 4 mm thread length; 3 mm head diameter; 0.8 mm head thickness
    • Type 8: M1.2x2; machine screw; 1.2 mm thread diameter; 0.25 mm thread pitch; 2 mm thread length; 2.2 mm head diameter; 0.4 mm head thickness
  1. Steam Deck Screw ID, Back cover: passo 2, imagem 1 %32 Steam Deck Screw ID, Back cover: passo 2, imagem 2 %32
    • Type 1: M1.6x9 plastic thread forming screw
    • Type 2: M1.6x5 machine screw
  2. Steam Deck Screw ID, Back cover removed: passo 3, imagem 1 %32 Steam Deck Screw ID, Back cover removed: passo 3, imagem 2 %32
    • Type 3: M2x3.5 machine screw
    • Type 4: M1.5x4.5 plastic thread forming screw
    • Type 5: M1.6x3 machine screw
  3. Steam Deck Screw ID, Motherboard shield removed: passo 4, imagem 1 %32 Steam Deck Screw ID, Motherboard shield removed: passo 4, imagem 2 %32
    • Type 6: M2x2.2 machine screw
  4. Steam Deck Screw ID, Trigger area: passo 5, imagem 1 %32 Steam Deck Screw ID, Trigger area: passo 5, imagem 2 %32
  5. Steam Deck Screw ID, Bumper area: passo 6, imagem 1 %32 Steam Deck Screw ID, Bumper area: passo 6, imagem 2 %32
  6. Steam Deck Screw ID, Trackpad area: passo 7, imagem 1 %32 Steam Deck Screw ID, Trackpad area: passo 7, imagem 2 %32
    • Type 7: M1.6x4 plastic thread forming screw
  7. Steam Deck Screw ID, Midframe: passo 8, imagem 1 %32 Steam Deck Screw ID, Midframe: passo 8, imagem 2 %32
  8. Steam Deck Screw ID, Under display: passo 9, imagem 1 %32 Steam Deck Screw ID, Under display: passo 9, imagem 2 %32
    • Type 8: M1.2x2 machine screw
Um comentário
Is there a way to convert these sizes to the ones used in the rest of the guides?
such as: M1.6x4= 4.7mm
Emojitsu Gaming - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 8
Últimos 7 dias: 63
Últimos 30 dias: 322
Duração total: 2,717
