Ir para o conteúdo principal
Vídeo de Apresentação
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Steam Deck, use o nosso manual de serviço.
  1. Steam Deck Chip ID, Side 1: passo 1, imagem 1 %32 Steam Deck Chip ID, Side 1: passo 1, imagem 2 %32
    • IC Identification, Pt. 1:
    • AMD/Valve 100-000000405 Quad-Core Application Processor w/ GPU
    • Micron MT62F1G32D4DR-031 WT:B 4 GB LPDDR5 SDRAM Memory
    • Winbond W25Q128JW 16 MB Serial NOR FLASH Memory
    • Analogix ANX7580 DisplayPort to Single MIPI Receiver
    • Cirrus Logic CS35L41B Audio Amplifier
    • Maxim Integrated MAX77961 USB Type-C Li-Ion Battery Charger
    • O2Micro OZ536 Backlight LED Driver
    Can i buy a part? Part name is Analogix ANX7580 DisplayPort to Single MIPI Receiver
    MUHAMMAD FIKRI HAIKAL - Responder
  2. Steam Deck Chip ID: passo 2, imagem 1 %32
    • IC Identification, Pt. 2:
    • Monolithic Power Systems MP2845 Digital 6-Phase Controller
    • Monolithic Power Systems MP86902B 35 A Power Stage
    • Monolithic Power Systems MP86903C Power Stage
    • Likely Monolithic Power Systems NB688C Synchronous Buck Converter
    • Monolithic Power Systems NB691 Synchronous Buck Converter
    • Monolithic Power Systems NB690G Synchronous Buck Converter
    • Possibly Monolithic Power Systems NB591 Synchronous Buck Converter
  3. Steam Deck Chip ID, Side 2: passo 3, imagem 1 %32 Steam Deck Chip ID, Side 2: passo 3, imagem 2 %32
    • IC Identification:
    • ITE Tech IT5570VG Embedded Controller (likely)
    • O2Micro OZ711 Card Reader Controller
    • Maxim Integrated MAX77958 USB Type-C & USB Power Delivery Controller
    • Diodes Incorporated PI3USB102 USB 2.0 SPDT Analog Switch
    • Texas Instruments TPS22976 Load Switch
23 comentários
Interesting how Valve went with a full-custom APU from AMD. I thought they’d use an off-the-shelf chip like the 4500U.
Ethan Zuo - Responder
Yeah i know what you mean!
They most likely they where wanting it to not be that thick,
so not like a laptop or desktop CPU for it,
Due to it being kinda thick!
Ben Capehart -
I assume the only major difference between this and an off the shelf APU is that this APU just has everything the steam deck does not utilize disabled or removed for power consumption reasons. I doubt it goes much deeper than that.
Alyx -
Good Point
See what you mean
Ben Capehart -
The 4500u has 6 EC Vega GPU, while the Steameck APU has an 8 ECU RDNA 2 GPU. Plus the custom APU gives them more control than a OTS apu.
MJ26 Gaming -
There are actually some differences, it has many differences than typical off-the-shelf APUs, now I don't know how much is firmware and how much is actually silicon but they had a section with AMD engineers that go into detail, some of my takeaways is that inbetween cycles, if it's done doing what it was it goes into a very low power mode, and the other one being that they really went for consistency and not turbo clocks and stuff
Scribble -
On step 3 there are 3 chips marked with dark blue which should be a USB switch, they look like they might be the TPS2276 load switch. The package does not match with the package from the USB switch datasheet in any case.
CazH - Responder
There’s not much to disable.
And it’s probably not custom APU for them, but something that Dell haven;t bought.
They needed to go to this strange mix of zen2+radeon6xxx mix, because only zen2 was low-power then and starting from radeon 6xxxx it provides RayTracing and is more energy efficient then older chips.
Mobile zen3 wasn’t released then. Now they would go this route.
Krzysztof Krakowiak - Responder
Microsoft, not Dell. Rumour has it that this was a part originally designed for an MS mobile device that the pandemic killed off: hence the presence of a machine vision IP block on the die that the Deck doesn't use and is most unlikely ever to.
Nick Alcock -
what about USB C port repair. doesnt seem like a simple thing . specially if ud end up replacing the whole board.
iWantOneToo - Responder
Hmm idk,
I bet its on the logic board
Ben Capehart -
Не вижу проблемы поменять порт usb C. Сплав Розе вам для скорости
FixMan -
any way to replace the wifi card? (If that isnt embedded into the APU or motherboard somehow)
Scribble - Responder
It's replaceable, :D
On the lower right side of the "side 1"
Is the WI-FI card port
Ben Capehart - Responder
When will I be able to buy the motherboard?
Jing - Responder
Yes, ifixit has them.
Ben Capehart -
I'd like to know what the USB controller for this thing is. The PD controller is labeled, and it seems there's a USB 2.0 de/multiplexor in there that's labeled. But...nothing USB 3? Does the USB C signal just go straight to the APU or something??
Matthew Fisher - Responder
Hmm.
that's a possibility!
I have No Idea
Ben Capehart -
Where I can buy the Maxim Integrated MAX77961 charger USB C?
Joel Davila - Responder
Guys, anyone khow what kind of ssd controller SD have. I heard that if u connect SSD with >1.6 A. Your SD SSD controller burnt. Any info. THX
Andii Kuziaiev - Responder
Does anyone know where can I buy a MAX77961 IC?
cakone micke - Responder
This is awesome thank you so much. I’m having a black screen issue. I thought it was the screen and got a new one but it still doesn’t work. I checked for shorts around “O2Micro OZ536 Backlight LED Driver” and didn’t see anything abnormal. Any tips?
Mike L - Responder
The OLED version has a Nuvoton NAU88L21YG audio codec chip on the motherboard. No codec chip is present in this publication for the LCD model but looking at the x-ray images, it seems the chip is actually on the headphone board for the LCD model. They also missed some other chips from other boards.
Mike - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 34
Últimos 7 dias: 241
Últimos 30 dias: 1,084
Duração total: 51,152
