Ir para o conteúdo principal
Starbucks Barista portafilter disassembly and cleaning
O que você precisa
  1. Starbucks Barista portafilter disassembly and cleaning, Starbucks Barista portafilter disassembly and cleaning: passo 1, imagem 1 %32
    • Turn the portafilter handle to the left to remove it from the machine.
    • Flip the portafilter over so the bottom with the 3 screws faces up.
  2. Starbucks Barista portafilter disassembly and cleaning: passo 2, imagem 1 %32 Starbucks Barista portafilter disassembly and cleaning: passo 2, imagem 2 %32
    • Before beginning, make a small, neat "scribe" mark on both the bottom edge of the plastic basket and, right next to it, the top of the metal basket. This match-marks these two pieces. Unscrew and remove the 3 phillips-head screws.
    • Lift off the plastic handle assembly, exposing the internal pressure system and two springs. Take note of the handle's orientation in relation to the metal piece as it will need to be re-attached in exactly the same position to function correctly.
  3. Starbucks Barista portafilter disassembly and cleaning: passo 3, imagem 1 %32 Starbucks Barista portafilter disassembly and cleaning: passo 3, imagem 2 %32
    • Take note of the spring's placement, then carefully remove and set them aside.
    • Clean the pressure assembly with a citrus-based cleaner and a brush, making sure to get under the hinged needle valve. Rinse well, then replace the springs.
    • Reattach the handle assembly with the 3 phillips-head screws. If assembled correctly the handle should pivot slightly in relation to the metal portion, than spring back when released.
Conclusão
13 outras pessoas executaram este guia.
David
Membro desde: 01/28/11
778 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 4-42, Regan Winter 2011 Membro de Cal Poly, Team 4-42, Regan Winter 2011
CPSU-REGAN-W11S4G42
4 Membros
Autoria de 11 guias
24Comentários do guia
Are there any pictures to show how to replace the gasket on the portafilter?
Scott - Responder Compartilhar
any luck on replacing the gasket?
Erica Fisher - Compartilhar
Yeah he needs to add a step 4.
Until he does, take a look at this YT video.
https://www.youtube.com/watch?v=MCf_zOEX...
Gary Naka - Compartilhar
i just did this and it worked. my problem was i kept thinking it wasnt working bc the water kept flowing out of the top and not going through the two holes into the cup. I figured out it needs the coffe grounds in there to actually work! thanks!
preceptgirl - Responder Compartilhar
Not true.
After I pull a shot, I always pull an EMPTY shot of just water and NO coffee, to clean the PF.
The only time I had water going over the top of the PF was when I put a SINGLE shot basket in, WITHOUT the rubber adapter under it.
Comentar
Visualizações:
Últimas 24 horas: 8
Últimos 7 dias: 31
Últimos 30 dias: 128
Ao todo: 44,019
