Ir para o conteúdo principal
Starbucks Barista Steam Wand replacement or cleaning
O que você precisa
  1. Starbucks Barista Steam Wand replacement or cleaning, steam wand: passo 1, imagem 1 %32
    • Using a wrench, unscrew the hex nut and remove the steam wand.
    • Note: Do not lose the hex nut once it is unscrewed.
  2. Starbucks Barista Steam Wand replacement or cleaning: passo 2, imagem 1 %32 Starbucks Barista Steam Wand replacement or cleaning: passo 2, imagem 2 %32
    • Using a thin tool or item, such as a paper clip, poke around through the holes on both ends of the wand to remove any foreign material.
    • Place the steam wand in a de-calcifying solution as directed by product.
    • Reconnect the steam wand.
    • See the links section of the device page to purchase a new steam wand.
Conclusão
4 outras pessoas executaram este guia.
David
Membro desde: 01/28/11
748 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 4-42, Regan Winter 2011 Membro de Cal Poly, Team 4-42, Regan Winter 2011
CPSU-REGAN-W11S4G42
Membros da 4
Autoria de 5 guias
Um comentário
To replace steam-wand seals (in case of water leaking out from the center of the steam-wand): https://www.youtube.com/watch?v=fulyy9A9... , but note - for parts: https://philips.encompass.com/model/SAER... (worth going to amazon.de and entering the partnumbers into the search box: e.g. the o-rings for the needle-valve (996530013462)
R Cly - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 36
Duração total: 15,882
