Ir para o conteúdo principal
Starbucks Barista Ready Light Replacement
O que você precisa
  1. Starbucks Barista Ready Light Replacement, Ready Light: passo 1, imagem 1 %32 Starbucks Barista Ready Light Replacement, Ready Light: passo 1, imagem 2 %32
    • Unscrew the 6 screws from the back panel.
    • Remove the back panel.
  2. Starbucks Barista Ready Light Replacement: passo 2, imagem 1 %32 Starbucks Barista Ready Light Replacement: passo 2, imagem 2 %32 Starbucks Barista Ready Light Replacement: passo 2, imagem 3 %32
    • Locate the ready light.
    • Gently push the fixture against the Barista wall.
    • Pull the fixture straight up to release it.
    • Note: The fixture works as a spring.
    • Note: The green cover from the front panel will "pop" off. Do not lose the green cover.
    • Disconnect the wire lead connectors.
    • Remove the ready light unit (fixture).
  3. Starbucks Barista Ready Light Replacement: passo 3, imagem 1 %32
    • Replace the old LED with a new LED.
    • To put back, match the green cover to the slot of the LED fixture, then slide the fixture down against the barista wall.
Conclusão
Uma outra pessoa concluiu este guia.
David
Membro desde: 01/28/11
766 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 4-42, Regan Winter 2011 Membro de Cal Poly, Team 4-42, Regan Winter 2011
CPSU-REGAN-W11S4G42
4 Membros
Autoria de 10 guias
4Comentários do guia
Youth and sports for
Rich Ridout - Responder
Where can I get a new LED bulb?
Paula - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 17
Ao todo: 6,285
