Introdução
If your sharpener is making a loud grinding noise or the electric motor is running but the cutter is not rotating, then follow these steps to replace the gears in your Staples 34462 Electric Pencil Sharpener.
O que você precisa
Using a Philips 00 screwdriver, remove the six 9.87mm screws securing the gear housing.
Uma outra pessoa concluiu este guia.
