Ir para o conteúdo principal
Staples 34462 Electric Pencil Sharpener Cover
O que você precisa
  1. Staples 34462 Electric Pencil Sharpener Cover, Cover: passo 1, imagem 1 %32
    • Pull out the shavings tray from the pencil sharpener.
    • Beware of loose pencil shavings falling on your workspace.
  2. Staples 34462 Electric Pencil Sharpener Cover: passo 2, imagem 1 %32
    • Turn the pencil sharpener on its side.
  3. Staples 34462 Electric Pencil Sharpener Cover: passo 3, imagem 1 %32
    • Using a Phillips00 screwdriver, remove the two front 11.6mm screws.
    • Using the plastic opening tool, remove the back plastic feet.
    • After removing the back plastic feet, using a Phillips 00 screwdriver, remove the two back 11.6mm screws.
    • The hole is deeper than you may think. It may take some time to get the screwdriver to click in.
  4. Staples 34462 Electric Pencil Sharpener Cover: passo 4, imagem 1 %32
    • Carefully pull apart the bottom panel from the top panel.
    • Be careful not to pull too forcefully as the panels are connected by wires.
    • Beware of pencil shavings falling out onto your workspace.
  5. Staples 34462 Electric Pencil Sharpener Cover: passo 5, imagem 1 %32
    • Using a Phillips00 screwdriver, remove two 8.9mm flat edge screws from the top section of the top panel.
  6. Staples 34462 Electric Pencil Sharpener Cover: passo 6, imagem 1 %32
    • Using a Phillips00 screwdriver, remove two 10.3mm screws from the middle section of the top panel.
  7. Staples 34462 Electric Pencil Sharpener Cover: passo 7, imagem 1 %32
    • Carefully pull the cover from the top panel and set it aside.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 27
Duração total: 884
