Ir para o conteúdo principal
Stanley 10-079 Box Cutter Blade Replacement
O que você precisa
  1. Stanley 10-079 Box Cutter Blade  Replacement, Knife Blade: passo 1, imagem 1 %32
    • Here is the knife we will be replacing the blade on, its a Stanley 10-079 Box Cutter.
  2. Stanley 10-079 Box Cutter Blade  Replacement: passo 2, imagem 1 %32
    • Using a screwdriver or a coin remove the single screw in the center of the box cutter
  3. Stanley 10-079 Box Cutter Blade  Replacement: passo 3, imagem 1 %32
    • Carefully pull up on the top half of the cutter exposing the blade on the inside.
  4. Stanley 10-079 Box Cutter Blade  Replacement: passo 4, imagem 1 %32
    • carefully without cutting yourself lift the old blade out this should require no force.
  5. Stanley 10-079 Box Cutter Blade  Replacement: passo 5, imagem 1 %32
    • with the old blade out replace it with a new blade from the back or one that was purchased separately.
  6. Stanley 10-079 Box Cutter Blade  Replacement, Reassembly: passo 6, imagem 1 %32 Stanley 10-079 Box Cutter Blade  Replacement, Reassembly: passo 6, imagem 2 %32
    • With the fresh blade in place carefully place the upper half of the box cutter on the lower half that contains the blade as shown in image number 2.
  7. Stanley 10-079 Box Cutter Blade  Replacement, Final Assembily: passo 7, imagem 1 %32
    • insert the screw you first removed back into the hole in the center ensuring that you tighten it down not too tight to get undone without a power tool
  8. Stanley 10-079 Box Cutter Blade  Replacement: passo 8, imagem 1 %32
    • With the center screw re-installed you are all set to use your Stanley 10-079 box cutter again with a brand new blade.
Conclusão
You are all set and ready to use your brand new installed blade! Here are some replacement blades that I found on amazon. https://www.amazon.com/Stanley-11-921L-5...
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 61
Ao todo: 6,650
