Ir para o conteúdo principal
Squier Strat Guitar Pickups Replacement
O que você precisa
  1. Squier Strat Guitar Pickups Replacement, Pickups: passo 1, imagem 1 %32 Squier Strat Guitar Pickups Replacement, Pickups: passo 1, imagem 2 %32
    • With a screwdriver, unscrew the back panel screws.
    • Remove back panel.
  2. Squier Strat Guitar Pickups Replacement: passo 2, imagem 1 %32
    • Unwind and remove the guitar strings.
  3. Squier Strat Guitar Pickups Replacement: passo 3, imagem 1 %32
    • With a screwdriver, remove the front body perimeter screws.
  4. Squier Strat Guitar Pickups Replacement: passo 4, imagem 1 %32
    • Carefully lift the panel of the guitar and turn it upside down to reveal the electronic components.
  5. Squier Strat Guitar Pickups Replacement: passo 5, imagem 1 %32 Squier Strat Guitar Pickups Replacement: passo 5, imagem 2 %32
    Ferramenta utilizada neste passo:
    Desoldering Pump
    $3.99
    • Using the the soldering iron and the solder sucker (or the soldering wick), take away any soldering connections of the potentiometers and the five-way switch.
  6. Squier Strat Guitar Pickups Replacement: passo 6, imagem 1 %32
    • Carefully flip the back panel to the original position.
    • With a screwdriver, unscrew the pickups.
  7. Squier Strat Guitar Pickups Replacement: passo 7, imagem 1 %32
    • Remove the old pickups.
Conclusão
Uma outra pessoa concluiu este guia.
Ion
Membro desde: 09/29/15
479 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 10-5, Green Fall 2015 Membro de Cal Poly, Team 10-5, Green Fall 2015
CPSU-GREEN-F15S10G5
Membros da 3
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 4
Duração total: 1,268
