Ir para o conteúdo principal
Spy Gear Video Walkie Talkies Camera Replacement
O que você precisa
  1. Spy Gear Video Walkie Talkies Camera Replacement, Top Cover: passo 1, imagem 1 %32
    • Remove the battery cover by removing the P1 Philips screw.
    • Remove the 3 AA batteries by hand.
  2. Spy Gear Video Walkie Talkies Camera Replacement: passo 2, imagem 1 %32
    • Unscrew Top Cover with a 3mm Triangle driver bit from the Driver Kit.
  3. Spy Gear Video Walkie Talkies Camera Replacement: passo 3, imagem 1 %32
    • Use Opening Tool to release barbed latch on top cover.
  4. Spy Gear Video Walkie Talkies Camera Replacement: passo 4, imagem 1 %32
    • Release pilot studs near the hinge with Metal Spudger.
  5. Spy Gear Video Walkie Talkies Camera Replacement: passo 5, imagem 1 %32
    • Once the Top Cover is free, you will have full access to the circuitry.
  6. Spy Gear Video Walkie Talkies Camera Replacement, Camera: passo 6, imagem 1 %32
    • Use Tweezers to remove the side button.
  7. Spy Gear Video Walkie Talkies Camera Replacement: passo 7, imagem 1 %32 Spy Gear Video Walkie Talkies Camera Replacement: passo 7, imagem 2 %32
    • Release the zero insertion force (ZIF) connector.
    • Pull the ribbon cable away carefully.
  8. Spy Gear Video Walkie Talkies Camera Replacement: passo 8, imagem 1 %32
    • With the ribbon cable free from obstructions, use a Prying Tool to release the circuit board from the guide studs.
  9. Spy Gear Video Walkie Talkies Camera Replacement: passo 9, imagem 1 %32
    • With a plastic Prying Tool, separate the screen from the mounting tray.
    • Adhesive between the layers may provoke damage to the screen or tray. Take your time.
  10. Spy Gear Video Walkie Talkies Camera Replacement: passo 10, imagem 1 %32
    • Once the screen is completely folded away from the mounting tray, release it from the circuit board by hand.
  11. Spy Gear Video Walkie Talkies Camera Replacement: passo 11, imagem 1 %32
    • Release the back of the mounting tray using a plastic Pick to unhook the barb from the circuit board.
  12. Spy Gear Video Walkie Talkies Camera Replacement: passo 12, imagem 1 %32
    • Now remove the mounting tray complete with camera and ribbon cable attached by sliding away from the screen.
    • You must not damage the screen or screen ribbon cable in this step.
  13. Spy Gear Video Walkie Talkies Camera Replacement: passo 13, imagem 1 %32
    • Discard faulty camera and mounting tray.
Conclusão
James French
Membro desde: 02/15/16
151 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team 7-7, Wilson Spring 2016 Membro de IUPUI, Team 7-7, Wilson Spring 2016
IUPUI-WILSON-S16S7G7
Membros da 5
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 10
Duração total: 630
