Peças
Não são necessárias peças.
Push the gray lever up towards the top of the phone.
Pull up on the battery pack and completely separate it from the phone.
Locate the 5 screws around the back casing.
Use a three-prong screw bit to remove all 5 screws
Use the plastic opening tool and slide it around the phone to pull apart the front and back casing.
Use the plastic opening tool to remove the motherboard from the front case.
Use a Phillips-head screw bit to remove the screw under the yellow film
Uma outra pessoa concluiu este guia.
