Ir para o conteúdo principal
Sprint Sanyo RL-4920 Speaker Replacement
O que você precisa
  1. Sprint Sanyo RL-4920 Speaker Replacement, Back of Phone: passo 1, imagem 1 %32
    • Flip the phone over so that the screen is facing down.
  2. Sprint Sanyo RL-4920 Speaker Replacement, Remove Battery Pack: passo 2, imagem 1 %32 Sprint Sanyo RL-4920 Speaker Replacement, Remove Battery Pack: passo 2, imagem 2 %32
    • Push the gray lever up towards the top of the phone.
    • Pull up on the battery pack and completely separate it from the phone.
  3. Sprint Sanyo RL-4920 Speaker Replacement, Screws: passo 3, imagem 1 %32 Sprint Sanyo RL-4920 Speaker Replacement, Screws: passo 3, imagem 2 %32
    • Locate the five screws around the back casing.
    • Use a three-prong screw bit to remove all five screws.
  4. Sprint Sanyo RL-4920 Speaker Replacement, Separate Cases: passo 4, imagem 1 %32
    • Use the plastic opening tool and slide it around the phone to pull apart the front and back casing.
  5. Sprint Sanyo RL-4920 Speaker Replacement, Separate Cases: passo 5, imagem 1 %32
    • Separate the two cases.
  6. Sprint Sanyo RL-4920 Speaker Replacement, The Front Case: passo 6, imagem 1 %32
    • Use the plastic opening tool to remove the motherboard from the front case.
  7. Sprint Sanyo RL-4920 Speaker Replacement, Screws: passo 7, imagem 1 %32 Sprint Sanyo RL-4920 Speaker Replacement, Screws: passo 7, imagem 2 %32
    • Locate the three screws securing the speaker.
    • Use a Phillips-head screw bit to unscrew the screws
  8. Sprint Sanyo RL-4920 Speaker Replacement, Replace Speaker: passo 8, imagem 1 %32
    • Remove the speaker.
    • Replace with new speaker.
    • Secure new speaker with screws and reassemble phone.
Conclusão
Austin Shores
Membro desde: 10/18/13
301 Reputação
Autoria de 3 guias
Equipe
Clemson, Team 13-5, Benson Fall 2013 Membro de Clemson, Team 13-5, Benson Fall 2013
CLEM-BENSON-F13S13G5
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 168
