Ir para o conteúdo principal
Sprint Sanyo RL-4920 Display Replacement
O que você precisa
  1. Sprint Sanyo RL-4920 Display Replacement, Back of Phone: passo 1, imagem 1 %32
    • Flip the phone over so that the screen is facing down.
  2. Sprint Sanyo RL-4920 Display Replacement, Remove Battery Pack: passo 2, imagem 1 %32 Sprint Sanyo RL-4920 Display Replacement, Remove Battery Pack: passo 2, imagem 2 %32
    • Push the gray lever up towards the top of the phone.
    • Pull up on the battery pack and completely separate it from the phone.
  3. Sprint Sanyo RL-4920 Display Replacement, Screws: passo 3, imagem 1 %32 Sprint Sanyo RL-4920 Display Replacement, Screws: passo 3, imagem 2 %32
    • Locate the five screws around the back casing.
    • Use a three-prong screw bit to remove all five screws.
  4. Sprint Sanyo RL-4920 Display Replacement, Separate Cases: passo 4, imagem 1 %32
    • Use the plastic opening tool and slide it around the phone to pull apart the front and back casing.
  5. Sprint Sanyo RL-4920 Display Replacement, Separate Cases: passo 5, imagem 1 %32
    • Separate the two cases.
  6. Sprint Sanyo RL-4920 Display Replacement, The Front Case: passo 6, imagem 1 %32
    • Use the plastic opening tool to remove the motherboard from the front case.
  7. Sprint Sanyo RL-4920 Display Replacement, Display: passo 7, imagem 1 %32 Sprint Sanyo RL-4920 Display Replacement, Display: passo 7, imagem 2 %32
    • Locate the 4 white clips of the dispaly.
  8. Sprint Sanyo RL-4920 Display Replacement: passo 8, imagem 1 %32 Sprint Sanyo RL-4920 Display Replacement: passo 8, imagem 2 %32
    • Using the plastic opening tool, pull the white clips of the display away from the printed circuit board to unclip display.
  9. Sprint Sanyo RL-4920 Display Replacement: passo 9, imagem 1 %32 Sprint Sanyo RL-4920 Display Replacement: passo 9, imagem 2 %32
    • Grasp the display on both sides and carefully pull the display off of the printed circuit board.
  10. Sprint Sanyo RL-4920 Display Replacement: passo 10, imagem 1 %32 Sprint Sanyo RL-4920 Display Replacement: passo 10, imagem 2 %32
    • Using the plastic opening tool, carefully remove the yellow film covering the display connector.
    • Do not damage the yellow film. Ensure that it stays in one piece and does not tear.
Conclusão
Uma outra pessoa concluiu este guia.
Patrick Olmstead
Membro desde: 10/22/13
240 Reputação
Autoria de 2 guias
Equipe
Clemson, Team 13-5, Benson Fall 2013 Membro de Clemson, Team 13-5, Benson Fall 2013
CLEM-BENSON-F13S13G5
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 257
