Ir para o conteúdo principal
Sprinkler Head Replacement
O que você precisa
  1. Sprinkler Head Replacement, Sprinkler Head: passo 1, imagem 1 %32
    • Turn off the water supply to the sprinklers.
    • This process will vary depending on your sprinkler controller.
  2. Sprinkler Head Replacement: passo 2, imagem 1 %32
    • Find where the water supply feeds the sprinkler system and close the valve in the event of emergency or unforeseen circumstances.
  3. Sprinkler Head Replacement: passo 3, imagem 1 %32
    • Dig a hole down to the base of the sprinkler head.
    • Be careful to avoid puncturing the sprinkler line.
  4. Sprinkler Head Replacement: passo 4, imagem 1 %32
    • Using your hand or a gardening trowel, finish digging so that the sprinkler head is fully visible and is clear of dirt and debris.
  5. Sprinkler Head Replacement: passo 5, imagem 1 %32 Sprinkler Head Replacement: passo 5, imagem 2 %32
    • Unscrew the sprinkler head from the line it is attached to.
    • If is loose enough you may not need pliers.
  6. Sprinkler Head Replacement: passo 6, imagem 1 %32 Sprinkler Head Replacement: passo 6, imagem 2 %32
    • Coat the threads of the water line with teflon tape to avoid leaking.
  7. Sprinkler Head Replacement: passo 7, imagem 1 %32 Sprinkler Head Replacement: passo 7, imagem 2 %32
    • Using your hand, screw the new sprinkler head on over the teflon tape.
    • Once the sprinkler head is hand tight, use pliers to tighten it by another half turn.
  8. Sprinkler Head Replacement: passo 8, imagem 1 %32
    • Fill the hole in and pack it down to avoid unwanted movement of the new sprinkler head.
  9. Sprinkler Head Replacement: passo 9, imagem 1 %32
    • Turn the sprinkler system on.
  10. Sprinkler Head Replacement: passo 10, imagem 1 %32
    • Twist the top of the sprinkler until it is aimed where you want it.
  11. Sprinkler Head Replacement: passo 11, imagem 1 %32
    • Use a flat head screwdriver to adjust the flow of water if needed.
    • Turning right decreases the water flow. Turning left increases the water flow.
Conclusão
Enjoy your green lawn and water savings.
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 25
Duração total: 585
